[gdal-dev] gdal_translate shifted values
Roger Bivand Roger.Bivand at nhh.no
Thu Feb 1 04:06:41 PST 2024
>From the R code snippet I see: "Surprisingly, the value 9.75 is shifted to 106, 86 = 105,85 in Python indexing", but R is 1-base and Python 0-base. In R:
> library(terra)
terra 1.7.71
> gdal()
[1] "3.8.3"
> a <- rast("attachment.obj")
> b <- rast("st4_pr.2017092016.01h.tif")
> a
class       : SpatRaster
dimensions  : 205, 205, 1  (nrow, ncol, nlyr)
resolution  : 4762, 4762  (x, y)
extent      : 4940902, 5917112, -7210793, -6234583  (xmin, xmax, ymin, ymax)
coord. ref. : +proj=stere +lat_0=90 +lat_ts=60 +lon_0=-105 +x_0=0 +y_0=0 +R=6367470 +units=m +no_defs
source      : attachment.obj
name        : SFC (Ground or water surface); Total precipitation [kg/m^2]
unit        :                                                      kg/m^2
time        : 2017-09-20 16:00:00 UTC
> b
class       : SpatRaster
source      : st4_pr.2017092016.01h.tif
name        : 0[-] SFC (Ground or water surface)
> all.equal(values(a), values(b))
[1] "Attributes: < Component \"dimnames\": Component 2: 1 string mismatch >"
> dimnames(values(a))
[[1]]
NULL
[[2]]
[1] "SFC (Ground or water surface); Total precipitation [kg/m^2]"
> dimnames(values(b))
[[1]]
NULL
[[2]]
[1] "0[-] SFC (Ground or water surface)"
> all.equal(values(a), values(b), check.attributes=FALSE)
[1] TRUE
Reading both into R shows that the input GRIB data and the GTiff data converted by gdal_translate are identical.
By the way, better to use the terra package directly, raster uses it indirectly.
Hope this clarifies,
Roger
Roger Bivand
Emeritus Professor
Norwegian School of Economics
Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway
