[gdal-dev] gdal_rasterize "burn count" feature
Laurențiu Nicola lnicola at dend.ro
Thu Feb 1 07:14:01 PST 2024
You can use -sql and -a to burn a field of the query.
Laurentiu
On Thu, Feb 1, 2024, at 17:11, Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC] via gdal-dev wrote:
> Hi,
> We’d like to use gdal_rasterize to burn in a value that is a simple numerical function of the feature geometry.  Currently we pre-process the feature database, store the value into a new field, and then burn that in.  It works, but it would be handy to be able to express this directly to gdal_rasterize.  I see sql can be leveraged to select which features to burn in, but nothing regarding programmable burn values.
> Jesse
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240201/74b3787e/attachment.htm>
