[gdal-dev] core dump on dir info
Michael Sumner mdsumner at gmail.com
Sat Feb 3 21:20:32 PST 2024
skipping TileDB does fix:
ogr2ogr /tmp/newdir
https://github.com/SymbolixAU/geojsonsf/raw/master/inst/examples/geo_melbourne.geojson
-f
"ESRI Shapefile"
export GDAL_SKIP=TileDB
ogrinfo /tmp/newdir/
INFO: Open of `/tmp/newdir/'
      using driver `ESRI Shapefile' successful.
1: geo_melbourne (Polygon)
unset GDAL_SKIP
Illegal instruction (core dumped)
I failed to explain that I'm using gdal containers from the repo:
docker run --rm -ti ghcr.io/osgeo/gdal:ubunt
u-full-latest
apt update
apt install -y gdb
Here's the output of under gdb as you suggested, there was a lot so I put
it on a gist:
https://gist.github.com/mdsumner/839ae6e05ededf640b65bfee3a20a4c0
gdb --args ogrinfo /tmp/newdir/
> run
> thread apply all bt
Thanks!
On Sat, Feb 3, 2024 at 7:49 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> - When it crashes under gdb, type "thread apply all bt" to get the stack
> trace of all threads
> - I suspect there is a connection with
> https://github.com/OSGeo/gdal/pull/9170 , but that pull request wouldn't
> help here as "/tmp/newdir" could be a valid connection to TileDB
> - how did you get TileDB installed? It looks to be packaged? Which
> distribution do you use?
> - SIGILL reminds me of issues with some TileDB builds using the AVX2
> instruction set by default, which could cause some crash on host CPUs that
> don't have AVX2 (unlikely on recent hardware though)
> - Setting GDAL_SKIP=TileDB should be a workaround
> Le 03/02/2024 à 07:15, Michael Sumner a écrit :
> Thanks Even, so there's something about tiledb under gdb (or maybe I am
> mangling the context,  I will try variants of the host I'm using). Run with
> valgrind included below.
> (gdb) run
> Starting program: /usr/local/bin/ogrinfo /tmp/newdir/
> [Thread debugging using libthread_db enabled]
> Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
> [New Thread 0x7fffe7757640 (LWP 988)]
> [New Thread 0x7fffe6f56640 (LWP 989)]
> [New Thread 0x7fffde755640 (LWP 990)]
> [New Thread 0x7fffd5f54640 (LWP 991)]
> [New Thread 0x7fffc5753640 (LWP 992)]
> [New Thread 0x7fffc4f52640 (LWP 993)]
> [New Thread 0x7fffb4751640 (LWP 994)]
> [New Thread 0x7fffabf50640 (LWP 995)]
> [New Thread 0x7fffab74f640 (LWP 996)]
> [New Thread 0x7fffa2f4e640 (LWP 997)]
> [New Thread 0x7fff9a74d640 (LWP 998)]
> [New Thread 0x7fff91f4c640 (LWP 999)]
> [New Thread 0x7fff8974b640 (LWP 1000)]
> [New Thread 0x7fff78f4a640 (LWP 1001)]
> [New Thread 0x7fff78749640 (LWP 1002)]
> [New Thread 0x7fff6f5ff640 (LWP 1003)]
> Thread 1 "ogrinfo" received signal SIGILL, Illegal instruction.
> 0x00007ffff3773c9e in tiledb::common::ThreadPool::ThreadPool(unsigned
> long) () from /lib/x86_64-linux-gnu/libtiledb.so.2.16
> valgrind -s ogrinfo /tmp/newdir
> ==704== Memcheck, a memory error detector
> ==704== Copyright (C) 2002-2017, and GNU GPL'd, by Julian Seward et al.
> ==704== Using Valgrind-3.18.1 and LibVEX; rerun with -h for copyright info
> ==704== Command: ogrinfo /tmp/newdir
> ==704==
> INFO: Open of `/tmp/newdir'
> ==704==
> ==704== HEAP SUMMARY:
> ==704==     in use at exit: 25,486 bytes in 216 blocks
> ==704==   total heap usage: 15,761 allocs, 15,545 frees, 2,390,169 bytes
> allocated
> ==704==
> ==704== LEAK SUMMARY:
> ==704==    definitely lost: 0 bytes in 0 blocks
> ==704==    indirectly lost: 0 bytes in 0 blocks
> ==704==      possibly lost: 544 bytes in 1 blocks
> ==704==    still reachable: 24,942 bytes in 215 blocks
> ==704==         suppressed: 0 bytes in 0 blocks
> ==704== Rerun with --leak-check=full to see details of leaked memory
> ==704==
> ==704== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 0 from 0)
> ogrinfo /tmp/newdir
> Cheers, Mike
> On Sat, Feb 3, 2024 at 12:46 PM Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Michael,
>> I'm wondering if there not might be something wrong with your build or
>> runtime environment. Or there's something subtle, because that works fine
>> for me with my dev build or in the ghcr.io/osgeo/gdal:alpine-normal-3.8.3
>> Docker image
>> Try running "valgrind ogrinfo /tmp/newdir/" or "gdb --args ogrinfo
>> /tmp/newdir/" (type "run") to get more useful information
>> Even
>> Le 03/02/2024 à 02:35, Michael Sumner via gdal-dev a écrit :
>> I'm getting Illegal instruction / core dumped on ogrinfo of a directory:
>> ogr2ogr /tmp/newdir
>> -f "ESRI Shapefile"
>> I've worked back through some docker images and it wasn't a problem in
>> 3.6.0, but I'm getting it since 3.7.0 - or I'm doing something wrong
>> entirely.
>> Cheers, Mike
>> Michael Sumner
>> Software and Database Engineer
>> Australian Antarctic Division
>> Hobart, Australia
>> e-mail: mdsumner at gmail.com
>> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
>> -- http://www.spatialys.com
>> My software is free, but my time generally not.
> Michael Sumner
> Hobart, Australia
Michael Sumner
Hobart, Australia
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240204/cbe1e6b6/attachment.htm>
