[gdal-dev] core dump on dir info
Even Rouault even.rouault at spatialys.com
Sun Feb 4 17:04:25 PST 2024
ghcr.io/osgeo/gdal:ubuntu-full-latest has been regenerated with the
rebuild of TileDB without AVX2. I've also enabled the
drivers-with-external-depencies-built-as-plugin GDAL build mode, so it
is easy to just remove a given plugin by deleting the corresponding .so
in /usr/lib/x86_64-linux-gnu/gdalplugins
Even
Le 04/02/2024 à 22:51, Michael Sumner a écrit :
> indeed there's no avx2:
> cat /proc/cpuinfo|grep sse|head -n 1
> flags           : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge
> mca cmov pat pse36 clflush mmx fxsr sse sse2 syscall nx mmxext
> fxsr_opt pdpe1gb rdtscp lm rep_good nopl cpuid extd_apicid
> tsc_known_freq pni pclmulqdq ssse3 fma cx16 sse4_1 sse4_2 x2apic
> popcnt tsc_deadline_timer aes xsave avx f16c hypervisor lahf_lm
> cmp_legacy svm cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw xop
> fma4 tbm perfctr_core ssbd ibpb vmmcall tsc_adjust bmi1 virt_ssbd arat
> npt nrip_save arch_capabilities
> Cheers, Mike
> On Sun, Feb 4, 2024 at 10:55 PM Even Rouault
> <even.rouault at spatialys.com> wrote:
>     ok, so I believe this is the AVX2 issue I was talking about, as I
>     realize that enabling AVX2 is the default mode when TileDB is
>     built from source (which the Docker image does), and must be
>     explicitly disabled with "./bootstrap --disable-avx2" (I've just
>     changed the build recipe to include that, will take effect next
>     time the images are refreshed)
>     To confirm, can you send or just check the output of : cat
>     If there is no "avx2" in it, this is at 99.9% the reason of the issue.
>     Even
>     Le 04/02/2024 à 06:20, Michael Sumner a écrit :
>>     skipping TileDB does fix:
>>     ogr2ogr /tmp/newdir
>>     https://github.com/SymbolixAU/geojsonsf/raw/master/inst/examples/geo_melbourne.geojson -f
>>     "ESRI Shapefile"
>>     export GDAL_SKIP=TileDB
>>     ogrinfo /tmp/newdir/
>>     INFO: Open of `/tmp/newdir/'
>>           using driver `ESRI Shapefile' successful.
>>     1: geo_melbourne (Polygon)
>>     unset GDAL_SKIP
>>     Illegal instruction (core dumped)
>>     I failed to explain that I'm using gdal containers from the repo:
>>     docker run --rm -ti ghcr.io/osgeo/gdal:ubunt
>>     <http://ghcr.io/osgeo/gdal:ubunt>
>>     u-full-latest
>>     apt update
>>     apt install -y gdb
>>     Here's the output of under gdb as you suggested, there was a lot
>>     so I put it on a gist:
>>     https://gist.github.com/mdsumner/839ae6e05ededf640b65bfee3a20a4c0
>>     gdb --args ogrinfo /tmp/newdir/
>>     > run
>>     > thread apply all bt
>>     Thanks!
>>     On Sat, Feb 3, 2024 at 7:49 PM Even Rouault
>>         - When it crashes under gdb, type "thread apply all bt" to
>>         get the stack trace of all threads
>>         - I suspect there is a connection with
>>         https://github.com/OSGeo/gdal/pull/9170 , but that pull
>>         request wouldn't help here as "/tmp/newdir" could be a valid
>>         connection to TileDB
>>         - how did you get TileDB installed? It looks to be packaged?
>>         Which distribution do you use?
>>         - SIGILL reminds me of issues with some TileDB builds using
>>         the AVX2 instruction set by default, which could cause some
>>         crash on host CPUs that don't have AVX2 (unlikely on recent
>>         hardware though)
>>         - Setting GDAL_SKIP=TileDB should be a workaround
>>         Le 03/02/2024 à 07:15, Michael Sumner a écrit :
>>>         Thanks Even, so there's something about tiledb under gdb (or
>>>         maybe I am mangling the context,  I will try variants of the
>>>         host I'm using). Run with valgrind included below.
>>>         (gdb) run
>>>         Starting program: /usr/local/bin/ogrinfo /tmp/newdir/
>>>         [Thread debugging using libthread_db enabled]
>>>         Using host libthread_db library
>>>         "/lib/x86_64-linux-gnu/libthread_db.so.1".
>>>         [New Thread 0x7fffe7757640 (LWP 988)]
>>>         [New Thread 0x7fffe6f56640 (LWP 989)]
>>>         [New Thread 0x7fffde755640 (LWP 990)]
>>>         [New Thread 0x7fffd5f54640 (LWP 991)]
>>>         [New Thread 0x7fffc5753640 (LWP 992)]
>>>         [New Thread 0x7fffc4f52640 (LWP 993)]
>>>         [New Thread 0x7fffb4751640 (LWP 994)]
>>>         [New Thread 0x7fffabf50640 (LWP 995)]
>>>         [New Thread 0x7fffab74f640 (LWP 996)]
>>>         [New Thread 0x7fffa2f4e640 (LWP 997)]
>>>         [New Thread 0x7fff9a74d640 (LWP 998)]
>>>         [New Thread 0x7fff91f4c640 (LWP 999)]
>>>         [New Thread 0x7fff8974b640 (LWP 1000)]
>>>         [New Thread 0x7fff78f4a640 (LWP 1001)]
>>>         [New Thread 0x7fff78749640 (LWP 1002)]
>>>         [New Thread 0x7fff6f5ff640 (LWP 1003)]
>>>         Thread 1 "ogrinfo" received signal SIGILL, Illegal instruction.
>>>         0x00007ffff3773c9e in
>>>         tiledb::common::ThreadPool::ThreadPool(unsigned long) ()
>>>         from /lib/x86_64-linux-gnu/libtiledb.so.2.16
>>>         valgrind -s ogrinfo /tmp/newdir
>>>         ==704== Memcheck, a memory error detector
>>>         ==704== Copyright (C) 2002-2017, and GNU GPL'd, by Julian
>>>         Seward et al.
>>>         ==704== Using Valgrind-3.18.1 and LibVEX; rerun with -h for
>>>         copyright info
>>>         ==704== Command: ogrinfo /tmp/newdir
>>>         ==704==
>>>         INFO: Open of `/tmp/newdir'
>>>         ==704==
>>>         ==704== HEAP SUMMARY:
>>>         ==704==     in use at exit: 25,486 bytes in 216 blocks
>>>         ==704==   total heap usage: 15,761 allocs, 15,545 frees,
>>>         2,390,169 bytes allocated
>>>         ==704==
>>>         ==704== LEAK SUMMARY:
>>>         ==704==    definitely lost: 0 bytes in 0 blocks
>>>         ==704==    indirectly lost: 0 bytes in 0 blocks
>>>         ==704==      possibly lost: 544 bytes in 1 blocks
>>>         ==704==    still reachable: 24,942 bytes in 215 blocks
>>>         ==704==         suppressed: 0 bytes in 0 blocks
>>>         ==704== Rerun with --leak-check=full to see details of
>>>         leaked memory
>>>         ==704==
>>>         ==704== ERROR SUMMARY: 0 errors from 0 contexts (suppressed:
>>>         0 from 0)
>>>         ogrinfo /tmp/newdir
>>>         Cheers, Mike
>>>         On Sat, Feb 3, 2024 at 12:46 PM Even Rouault
>>>             Michael,
>>>             I'm wondering if there not might be something wrong with
>>>             your build or runtime environment. Or there's something
>>>             subtle, because that works fine for me with my dev build
>>>             or in the ghcr.io/osgeo/gdal:alpine-normal-3.8.3
>>>             <http://ghcr.io/osgeo/gdal:alpine-normal-3.8.3> Docker image
>>>             Try running "valgrind ogrinfo /tmp/newdir/" or "gdb
>>>             --args ogrinfo /tmp/newdir/" (type "run") to get more
>>>             useful information
>>>             Even
>>>             Le 03/02/2024 à 02:35, Michael Sumner via gdal-dev a écrit :
>>>>             I'm getting Illegal instruction / core dumped on
>>>>             ogrinfo of a directory:
>>>>             ogr2ogr /tmp/newdir
>>>>             -f "ESRI Shapefile"
>>>>             I've worked back through some docker images and it
>>>>             wasn't a problem in 3.6.0, but I'm getting it since
>>>>             3.7.0 - or I'm doing something wrong entirely.
>>>>             Cheers, Mike
>>>>             Michael Sumner
>>>>             Software and Database Engineer
>>>>             Australian Antarctic Division
>>>>             Hobart, Australia
>>>>             e-mail: mdsumner at gmail.com
>>>>             _______________________________________________
>>>>             gdal-dev mailing list
>>>>             gdal-dev at lists.osgeo.org
>>>>             https://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>             http://www.spatialys.com
>>>             My software is free, but my time generally not.
>>>         Michael Sumner
>>>         Hobart, Australia
>>     Michael Sumner
>>     Hobart, Australia
> Michael Sumner
> Hobart, Australia
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240205/57931cc3/attachment-0001.htm>
