[gdal-dev] Compyle gdal >=3.7: lib2to3 error
andy aborruso at gmail.com
Mon Feb 5 15:00:09 PST 2024
I compile gdal 3.7 in this way:
mkdir -p build
cd build
cmake -D GDAL_USE_GEOS=ON -D OGR_ENABLE_DRIVER_PARQUET:BOOL=OFF -D
OGR_ENABLE_DRIVER_ARROW:BOOL=OFF ..
cmake --build .
sudo cmake --build . --target install
When I run "cmake --build ." I have this error:
Deprecated command line option: -py3. Ignored, this option is no longer
supported.
/usr/bin/python3.9: No module named lib2to3
How to solve this problem?
Thank you
___________________
Andrea Borruso
website: https://medium.com/tantotanto
38° 7' 48" N, 13° 21' 9" E, EPSG:4326
___________________
"cercare e saper riconoscere chi e cosa,
 in mezzo all’inferno, non è inferno,
e farlo durare, e dargli spazio"
Italo Calvino
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240206/c207a637/attachment.htm>
