[gdal-dev] [EXTERNAL] Re: GeoTiff JXL sample format & bits per sample restrictions?
Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC] jesse.r.meyer at nasa.gov
Fri Feb 9 06:36:49 PST 2024
Gladly,
Driver: GTiff/GeoTIFF
Files: in.tif
Size is 32000, 32000
Coordinate System is:
PROJCRS["Africa_Albers_Equal_Area_Conic",
    BASEGEOGCRS["WGS 84",
        DATUM["World Geodetic System 1984",
            ELLIPSOID["WGS 84",6378137,298.257223563,
                LENGTHUNIT["metre",1]]],
        PRIMEM["Greenwich",0,
            ANGLEUNIT["degree",0.0174532925199433]],
        ID["EPSG",4326]],
    CONVERSION["Albers Equal Area",
        METHOD["Albers Equal Area",
            ID["EPSG",9822]],
        PARAMETER["Latitude of false origin",0,
            ANGLEUNIT["degree",0.0174532925199433],
            ID["EPSG",8821]],
        PARAMETER["Longitude of false origin",25,
            ID["EPSG",8822]],
        PARAMETER["Latitude of 1st standard parallel",20,
            ID["EPSG",8823]],
        PARAMETER["Latitude of 2nd standard parallel",-23,
            ID["EPSG",8824]],
        PARAMETER["Easting at false origin",0,
            LENGTHUNIT["metre",1],
            ID["EPSG",8826]],
        PARAMETER["Northing at false origin",0,
            ID["EPSG",8827]]],
    CS[Cartesian,2],
        AXIS["easting",east,
            ORDER[1],
            LENGTHUNIT["metre",1,
                ID["EPSG",9001]]],
        AXIS["northing",north,
            ORDER[2],
                ID["EPSG",9001]]]]
Data axis to CRS axis mapping: 1,2
Origin = (-3800000.000000000000000,1928000.000000000000000)
Pixel Size = (0.500000000000000,-0.500000000000000)
Metadata:
  ACQDATE=2010-11-26 11:20:06.338865
  AREA_OR_POINT=Area
  CAT_ID=1050410001250C00
  CHIRPS=214.43
  CLOUDCOVER=0.0
  CLOUD_FRAC=0.0
  IMAGENAME=redacted.ntf
  MAX_AOD=0.233
  OFF_NADIR=11.8
  RESOLUTION=0.5
  RF_ADD=0.0
  RF_MULT=2000.0
  SAT_AZ=185.9
  SAT_ELEV=76.8
  SENSOR=GE01
  SUN_AZ=154.2
  SUN_ELEV=48.5
  TDI=16.0
Image Structure Metadata:
  COMPRESSION=ZSTD
  INTERLEAVE=BAND
  PREDICTOR=2
Corner Coordinates:
Upper Left  (-3800000.000, 1928000.000) ( 11d22' 1.85"W, 16d47' 0.21"N)
Lower Left  (-3800000.000, 1912000.000) ( 11d22'10.38"W, 16d38'30.31"N)
Upper Right (-3784000.000, 1928000.000) ( 11d12'50.68"W, 16d46'52.33"N)
Lower Right (-3784000.000, 1912000.000) ( 11d12'59.18"W, 16d38'22.44"N)
Center      (-3792000.000, 1920000.000) ( 11d17'30.52"W, 16d42'41.27"N)
Band 1 Block=256x256 Type=UInt16, ColorInterp=Gray
  Description = Panchromatic
  Min=1.000 Max=1734.000
  Minimum=1.000, Maximum=1734.000, Mean=489.009, StdDev=65.409
  NoData Value=0
  Metadata:
    STATISTICS_MAXIMUM=1734
    STATISTICS_MEAN=489.00875598419
    STATISTICS_MINIMUM=1
    STATISTICS_STDDEV=65.408895074611
    STATISTICS_VALID_PERCENT=99.999
Band 2 Block=256x256 Type=UInt16, ColorInterp=Undefined
  Description = NDVI
  Min=582.000 Max=1781.000
  Minimum=582.000, Maximum=1781.000, Mean=1103.895, StdDev=61.554
  NoData Value=0
  Metadata:
    STATISTICS_MAXIMUM=1781
    STATISTICS_MEAN=1103.8951663354
    STATISTICS_MINIMUM=582
    STATISTICS_STDDEV=61.553712802204
Date: Friday, February 9, 2024 at 9:33 AM
To: "Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC]" <jesse.r.meyer at nasa.gov>
Cc: "gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>
Subject: [EXTERNAL] Re: [gdal-dev] GeoTiff JXL sample format & bits per sample restrictions?
CAUTION: This email originated from outside of NASA.  Please take care when clicking links or opening attachments.  Use the "Report Message" button to report suspicious messages to the NASA SOC.
could you share the output of "gdalinfo in.tif" please?
On Fri, Feb 9, 2024 at 3:32 PM Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC] via gdal-dev <gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>> wrote:
We are trying to convert a 2 band int16 ZSTD compressed geotiff to JXL compression.  However for each band the following error message is given “ERROR 1: GetJXLDataType:Unsupported combination of SampleFormat and BitsPerSample”.
On GDAL 3.8.3, released 2024/01/04.  JXL v0.9.2
gdal_translate -ot int16 -co "COMPRESS=JXL" -co "NUM_THREADS=8" -co "TILED=YES" -co "SPARSE_OK=YES" -
co "INTERLEAVE=BAND" -co "JXL_LOSSLESS=YES" in.tif out_JXL.tif
The docs state an encode limitation for GDAL < 3.6 wrt interleave and band counts.  We’re not subject to that, unless there’s a bug, but I do wonder if we have nonetheless gone off the support path with band interleave with 2 bands?
Jesse
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240209/777158bc/attachment-0001.htm>
