[gdal-dev] Testing the driver
Even Rouault even.rouault at spatialys.com
Fri Feb 9 15:43:59 PST 2024
> To test your own development, you may have a more pleasant experience
> by directly running just the tests for your driver with something like
> "pytest autotest/ogr/ogr_miramon.py"  (be careful on Windows, the
> content of $build_dir/autotest is copied from $source_dir/autotest
> each time "cmake" is run, so if you edit your test .py file directly
> in the build directory, be super careful of not accidentally losing
> your work, and make sure to copy its content to the source directory
> first. That's admittedly an annoying point of the current test setup
> on Windows, compared to Unix where we use symbolic links)
Actually Dan figured out it was possible to run directly the tests
against your test file from the source directory, and not the one that
is copied. Cf https://github.com/OSGeo/gdal/pull/9224
So you can actually do from the build directory:
pytest -c autotest/pytest.ini ../autotest/ogr/ogr_gpx.py
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240210/d43bd757/attachment.htm>
