[gdal-dev] Antwort: Re: Build static GDAL-Lib and static GDAL-Apps
Michael Otto michael.otto at data-experts.de
Mon Feb 12 23:18:07 PST 2024
Hello Robert,
at the moment it's only about the Linux platform. And yes, it should be a
static compilation with all the necessary dependencies (including libtiff
and all the others).
I currently use an Ubuntu VM and use an Alpine-Linux Docker container for
compiling. First a static Geos library is created via cmake, then a static
Proj library (without Curl, because this currently leads to errors) and
then Gdal as a static library.
The basis of the script comes from this source:
https://github.com/OSGeo/gdal/issues/4815.
I have updated the version used to the current version and replaced the
existing './configure' and 'make' commands with cmake.
This is what it looks like:
Start docker:  docker run -it --rm -v $(pwd):/tmp golang:1.17.3-alpine3.13
/bin/sh /tmp/mo_gdalbuild.sh
mo_gdalbuild.sh
#!/bin/sh
rm -r /tmp/gdal-3.8.3
rm -r /tmp/gdal-3.8.3.tar.gz
rm -r /tmp/geos-3.12.1
rm -r /tmp/geos-3.12.1.tar.bz2
rm -r /tmp/proj-9.3.0
rm -r /tmp/proj-9.3.0.tar.gz
rm -r /tmp/mo_gdal_install
set -e
proxy="http://172.16.7.13:8080"
export HTTP_PROXY="$proxy"
export HTTPS_PROXY="$proxy"
GDAL_VERSION=3.8.3
PROJ_VERSION=9.3.0
GEOS_VERSION=3.12.1
apk add --no-cache \
    wget \
    coreutils \
    build-base \
    unzip \
    cmake
# statically linked version of PROJ.
    sqlite \
    sqlite-dev \
    sqlite-static \
    tiff \
    tiff-dev
cd /tmp
wget --no-verbose -e use_proxy=yes -e https_proxy=$proxy https:
//download.osgeo.org/proj/proj-${PROJ_VERSION}.tar.gz
tar -xzf proj-${PROJ_VERSION}.tar.gz
cd proj-${PROJ_VERSION}
mkdir build
cd build
cmake \
-DBUILD_SHARED_LIBS=OFF \
-DBUILD_TESTING=OFF \
-DBUILD_PROJSYNC=OFF \
-DCMAKE_BUILD_TYPE=Release \
-DCMAKE_INSTALL_PREFIX=/tmp/mo_gdal_install/proj/dist \
-DENABLE_CURL=OFF \
cmake --build .
cmake --build . --target install
# statically linked version of GEOS.
cd /tmp
//download.osgeo.org/geos/geos-${GEOS_VERSION}.tar.bz2
tar -xjf geos-${GEOS_VERSION}.tar.bz2
cd geos-${GEOS_VERSION}
mkdir build
cd build
cmake \
    -DCMAKE_INSTALL_PREFIX=/tmp/mo_gdal_install/geos/dist \
cmake --build .
# statically linked version of GDAL
# (a minimal version still needs to be configured !)
    jpeg-dev \
    libjpeg-turbo-static \
    openssl-libs-static \
    linux-headers
cd /tmp
wget --no-verbose -e use_proxy=yes -e http_proxy=$proxy http:
//download.osgeo.org/gdal/${GDAL_VERSION}/gdal-${GDAL_VERSION}.tar.gz
tar -xzf gdal-${GDAL_VERSION}.tar.gz
cd gdal-${GDAL_VERSION}
mkdir build
cd build
cmake \
-DBUILD_APPS=ON \
-DCMAKE_PREFIX_PATH=/tmp/mo_gdal_install/gdal \
-DCMAKE_INSTALL_PREFIX=/tmp/mo_gdal_install/gdal \
-DGEOS_INCLUDE_DIR=/tmp/mo_gdal_install/geos/dist/include \
-DGEOS_LIBRARY=/tmp/mo_gdal_install/geos/dist/lib64/libgeos_c.a \
-DPROJ_INCLUDE_DIR=/tmp/mo_gdal_install/proj/dist/include \
-DPROJ_LIBRARY_RELEASE=/tmp/mo_gdal_install/proj/dist/lib64/libproj.a \
-DBUILD_JAVA_BINDINGS=ON \
-DGDAL_JAVA_INSTALL_DIR=/tmp/mo_gdal_install/java \
-DGDAL_JAVA_JNI_INSTALL_DIR=/tmp/mo_gdal_install/java/jni \
cmake --build .
If I check the individual libraries created using 'ldd', I can see that
they are statically linked.
If I run 'ldd' on the resulting apps, it looks different. Everything is
still linked dynamically. This should be changed ;o).
Best regards
Michael
Von:    "Robert Coup" <robert.coup at koordinates.com>
An:     "Michael Otto" <michael.otto at data-experts.de>
Kopie:  gdal-dev at lists.osgeo.org
Datum:  12.02.2024 15:43
Betreff:        Re: [gdal-dev] Build static GDAL-Lib and static GDAL-Apps
Hi Michael,
On Mon, 12 Feb 2024 at 12:02, Michael Otto via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
The goal is to cast GDAL and all its dependencies (PROJ / GEOS / all
dependencies to system libraries / ...) into a static library and to
create the GDAL apps as static executable programs.
Which platform are you working on? If you need a fully static compilation
of everything all the way down including openssl + zlib + zstd + libtiff +
all the other libraries, using vcpkg[1] might be a reasonable approach. By
default it does static compilation on macOS & Linux, and it has a static
compilation option on Windows (the default on Windows is dynamic). It
doesn't support every compile option though, but it's customisable and if
you're after a reasonably vanilla GDAL it should work ok.
There should be no dynamic dependencies.
Note that GDAL + Proj (maybe others), have data files they rely on, so
while you may be able to get a single executable, you'll still need to
distribute these files. I can imagine ways around that, but they're
getting fairly complex.
Unfortunately, I have not had any success so far. The library is created
statically but the apps are not yet.
Does anyone have experience with this topic or possibly a procedure that
leads to success?
Can you share the process you've currently got to?
Rob :)
[1] https://github.com/microsoft/vcpkg
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240213/de90b356/attachment-0001.htm>
