[gdal-dev] linting test in Code Checks always fails
Laurențiu Nicola lnicola at dend.ro
Tue Feb 13 04:37:20 PST 2024
On Tue, Feb 13, 2024, at 14:25, Abel Pau via gdal-dev wrote:
> Hi,
> I am trying to make my code good for all Actions in the project.
I'm guessing you should remove https://github.com/AbelPau/gdal/tree/master/out/build/x64-Debug from git (and ideally squash at the end).
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240213/8117022d/attachment.htm>
