[gdal-dev] Antwort: Re: Build static GDAL-Lib and static GDAL-Apps
    Kai Pastor, DG0YT
    dg0yt at darc.de
    Tue Feb 13 23:35:52 PST 2024
Am 13.02.24 um 08:18 schrieb Michael Otto via gdal-dev:
> I currently use an Ubuntu VM and use an Alpine-Linux Docker container
> for compiling. First a static Geos library is created via cmake, then
> a static Proj library (without Curl, because this currently leads to
> errors) and then Gdal as a static library.
You must consider all transitive dependencies, build them in the right
order, and ensure that transitive link libraries are passed on down to
gdal and to the final app (with link libraries in correct order).
For more than a minimal build, it is really better solved by using
package managers such as vcpkg than by reinventing the wheel - each
dependency may add its own set of problems. A simplified(!) dependency
graph for a minimal build in vcpkg, just gdal core features + geos:
zlib:
libjpeg-turbo:
liblzma:
openssl:
nlohmann-json:
curl[openssl, ssl, non-http]: openssl, zlib
sqlite3[json1, tool]:
tiff[lzma, jpeg, zip]: libjpeg-turbo, liblzma, zlib
proj[tiff, net]: curl, nlohmann-json, sqlite3, tiff
libgeotiff: proj, tiff
json-c:
geos:
gdal: geos, json-c, libgeotiff, proj, tiff, zlib
So libgeotiff, proj, tiff, curl all come with transitive usage
requirements which depend on actual configuration.
This is impossible to reconstruct in CMake find modules (coming with
CMake or GDAL).
In vcpkg, ports (maintainers) ensure that usage requirements are
exported by each package (using CMake config or find module wrappers).
Kai
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240214/d26d93f1/attachment.htm>
