[gdal-dev] VSI sidecar and sibling file lookup
thomas bonfort thomas.bonfort at gmail.com
Thu Feb 15 08:45:43 PST 2024
Hi Sean,
I believe/recall this is very driver dependent. Some drivers will look for
their sidecars in the provided sibling files list returned by
VSISiblingFiles, whereas others will unconditionally try to open well-known
sidecar names they will have computed from their own name. IIRC I added
VSISiblingFiles so that some vsi backends (namely object storage based
ones) could explicitly return an empty list of sibling files in order to
prevent drivers to emit a subsequent Readdir() (which might break drivers
that require sidecar files to work, but speeds up those where sidecar files
are optional and not used in a cloud-storage environment (namely cogs) )
On Tue, Feb 13, 2024 at 6:12 PM Sean Gillies via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hi all,
> It's not clear to me from reading
> https://gdal.org/user/virtual_file_systems.html if VSI sidecar and
> sibling file lookup works in general, by design, or whether it's an
> implementation detail of the standard VSI filesystems ("vsizip", "vsicurl",
> etc.).
> More specifically: if I have a "/vsipyopener/foo.tif" object, do drivers
> always look for other files at paths precisely relative to that one? Does
> this vary among drivers?
> Sean Gillies
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240215/4c21a372/attachment.htm>
