[gdal-dev] Assert due to stack corruption in FlatGeoBuf export
Simon Eves simon.eves at heavy.ai
Fri Feb 23 15:42:28 PST 2024
I'm also testing a build that uses the latest *flatbuffers* 23.5.26, which
is a drop-in replacement and does not require the *VerifyField* change,
just in case the issue has been fixed since 2.0.6.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240223/bac737cd/attachment.htm>
