[gdal-dev] Some problems after updating
Even Rouault even.rouault at spatialys.com
Mon Feb 26 08:29:48 PST 2024
hi,
perhaps make sure that your PATH environment variable includes a
directory that contains the gdal.dll of *your* build (should likely be
D:\GitHub-repository\GDAL\build\Debug) before the one potentially coming
from vcpkg
Even
Le 26/02/2024 à 17:20, Abel Pau via gdal-dev a écrit :
> Hi,
> usually (and always works) I call this two sentences from command line
> in Windows:
> cmake -B D:\GitHub-repository\GDAL\build -S .
> -DCMAKE_TOOLCHAIN_FILE=C:/dev/vcpkg/vcpkg/scripts/buildsystems/vcpkg.cmake
> cmake --build D:\GitHub-repository\GDAL\build
> The first one generates all projects that I can open with Visual Studio
> The second one compilates all files, and it ens with no problems.
> To test is works I’ve been using lots of line commands, for example
> this one (using the program ogr2ogr):
> D:\GitHub-repository\GDAL\build\apps\Debug\ogr2ogr.exe
> D:\mapes\2023\GDAL\Versions\Misteri_V20_a_V11.pol
> D:\mapes\2023\GDAL\Versions\Misteri_V20.pol -progress -lco
> Version=V1.1 --config CPL_DEBUG ON
> It’s been working untiel today when next error appears:
> ogr2ogr.exe - No se encuentra el punto de entrada
> No se encuentra el punto de entrada del procedimiento
> ?TransformWithErrorCodes at OGRCoordinateTransformation@@UEAAH_KPEAN111PEAH at Z
> en la biblioteca de vínculos dinámicos
> D:\GitHub-repository\GDAL\build\apps\Debug\ogr2ogr.exe.
> D'acord
> What is the diference between today and yesterday?
> I’ve done 2 things:
> ·Download and Install VCPKG (the method that worked for me)
> ·.\vcpkg\bootstrap-vcpkg.bat
> ·.\vcpkg integrate install
> ·.\vcpkg install gdal --triplet=x64-windows
> And, of course, download lasts codes from GDAL to be on date before
> finishing the job I’m doing.
> So, can anyone put some light to this mistery? What I am doing wrong
> this time?
> There is some dependence I am using wrong?
> I am a little desperate with that kind of errors.
> Thanks a lot!
> *Abel Pau Garcia*
> *GIS developer*
> https://www.creaf.cat/sites/default/files/creaf-signature.png
> *a.pau at creaf.uab.cat* <mailto:a.pau at creaf.uab.cat>
> *Let's chat on Teams!*
> <https://teams.microsoft.com/l/chat/0/0?users=a.pau@creaf.uab.cat>
> *Tel. +34 934814277*
> https://www.creaf.cat/sites/default/files/so-en-signature.png
> https://www.creaf.cat/sites/default/files/twitter-icon-signature.png
> <https://twitter.com/CREAF_ecologia>https://www.creaf.cat/sites/default/files/linkedin-icon-signature.png
> <https://www.linkedin.com/company/1363052?trk=tyah&trkInfo=clickedVertical:company,clickedEntityId:1363052,idx:2-1-2,tarId:1465807877789,tas:creaf>https://www.creaf.cat/sites/default/files/youtube-icon-signature.png
> <https://www.youtube.com/c/creafecologia>https://www.creaf.cat/sites/default/files/instagram-icon-signature.png
> <https://www.instagram.com/CREAF_ecologia/>
> *www.creaf.cat* <http://www.creaf.cat>*| **http://blog.creaf.cat*
> <http://blog.creaf.cat>
> https://www.creaf.cat/sites/default/files/uab_logo_signatura.png
> CREAF. Campus UAB. Edifici C. 08193 Bellaterra (Barcelona)
> Before printing this electronic message, think about the environment.
> http://www.creaf.uab.cat/_signatura/line.gif
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240226/0a835046/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240226/0a835046/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240226/0a835046/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240226/0a835046/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240226/0a835046/attachment-0009.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240226/0a835046/attachment-0010.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240226/0a835046/attachment-0011.png>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240226/0a835046/attachment-0002.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240226/0a835046/attachment-0003.jpg>
