[gdal-dev] Some problems after updating
Even Rouault even.rouault at spatialys.com
Mon Feb 26 08:54:48 PST 2024
Perhaps try the good old methods: run the "clean" target and do a full
rebuild
Le 26/02/2024 à 17:48, Abel Pau via gdal-dev a écrit :
> It even now doesn’t work from Visual Studio itself.
> I don’t understand what have changed from yesterday to today (apart
> from updating vcpkg and gdal code itself).
> *De:*gdal-dev <gdal-dev-bounces at lists.osgeo.org> *En nombre de *Abel
> Pau via gdal-dev
> *Enviado el:* dilluns, 26 de febrer de 2024 17:42
> *Para:* Even Rouault <even.rouault at spatialys.com>;
> gdal-dev at lists.osgeo.org
> *Asunto:* Re: [gdal-dev] Some problems after updating
> Hi Even, thanks for your answer.
> I paste here some of my variables:
> After too many months perhaps there are things that are not necessary,
> but the one you sais is there:
> *GDAL_DATA *
> D:\GitHub-repository\GDAL\build\data
> *PATH *
> PATH%;
> D:\GitHub-repository\GDAL\build\Debug;
> C:\Users\a.pau\AppData\Local\GitHubDesktop\bin;
> C:\Program Files\Graphviz\bin;
> D:\GitHub-repository\odbc-cpp-wrapper\build\src\odbc\Release;
> D:\mapes\programes\make-3.81-bin\bin;
> But same error appears :(
> *De:*Even Rouault <even.rouault at spatialys.com>
> *Enviado el:* dilluns, 26 de febrer de 2024 17:30
> *Para:* Abel Pau <a.pau at creaf.uab.cat>; gdal-dev at lists.osgeo.org
> hi,
> perhaps make sure that your PATH environment variable includes a
> directory that contains the gdal.dll of *your* build (should likely be
> D:\GitHub-repository\GDAL\build\Debug) before the one potentially
> coming from vcpkg
> Even
> Le 26/02/2024 à 17:20, Abel Pau via gdal-dev a écrit :
>     Hi,
>     usually (and always works) I call this two sentences from command
>     line in Windows:
>     cmake -B D:\GitHub-repository\GDAL\build -S .
>     -DCMAKE_TOOLCHAIN_FILE=C:/dev/vcpkg/vcpkg/scripts/buildsystems/vcpkg.cmake
>     cmake --build D:\GitHub-repository\GDAL\build
>     The first one generates all projects that I can open with Visual
>     Studio
>     The second one compilates all files, and it ens with no problems.
>     To test is works I’ve been using lots of line commands, for
>     example this one (using the program ogr2ogr):
>     D:\GitHub-repository\GDAL\build\apps\Debug\ogr2ogr.exe
>     D:\mapes\2023\GDAL\Versions\Misteri_V20_a_V11.pol
>     D:\mapes\2023\GDAL\Versions\Misteri_V20.pol -progress -lco
>     Version=V1.1 --config CPL_DEBUG ON
>     It’s been working untiel today when next error appears:
>     ogr2ogr.exe - No se encuentra el punto de entrada
>     No se encuentra el punto de entrada del procedimiento
>     ?TransformWithErrorCodes at OGRCoordinateTransformation@@UEAAH_KPEAN111PEAH at Z
>     en la biblioteca de vínculos dinámicos
>     D:\GitHub-repository\GDAL\build\apps\Debug\ogr2ogr.exe.
>     D'acord
>     What is the diference between today and yesterday?
>     I’ve done 2 things:
>     1.Download and Install VCPKG (the method that worked for me)
>     2..\vcpkg\bootstrap-vcpkg.bat
>     3..\vcpkg integrate install
>     4..\vcpkg install gdal --triplet=x64-windows
>     And, of course, download lasts codes from GDAL to be on date
>     before finishing the job I’m doing.
>     So, can anyone put some light to this mistery? What I am doing
>     wrong this time?
>     There is some dependence I am using wrong?
>     I am a little desperate with that kind of errors.
>     Thanks a lot!
>     *Abel Pau Garcia*
>     *GIS developer*
>     https://www.creaf.cat/sites/default/files/creaf-signature.png
>     *a.pau at creaf.uab.cat* <mailto:a.pau at creaf.uab.cat>
>     *Let's chat on Teams!*
>     <https://teams.microsoft.com/l/chat/0/0?users=a.pau@creaf.uab.cat>
>     *Tel. +34 934814277*
>     https://www.creaf.cat/sites/default/files/so-en-signature.png
>     https://www.creaf.cat/sites/default/files/twitter-icon-signature.png
>     <https://twitter.com/CREAF_ecologia>https://www.creaf.cat/sites/default/files/linkedin-icon-signature.png
>     <https://www.linkedin.com/company/1363052?trk=tyah&trkInfo=clickedVertical:company,clickedEntityId:1363052,idx:2-1-2,tarId:1465807877789,tas:creaf>https://www.creaf.cat/sites/default/files/youtube-icon-signature.png
>     <https://www.youtube.com/c/creafecologia>https://www.creaf.cat/sites/default/files/instagram-icon-signature.png
>     <https://www.instagram.com/CREAF_ecologia/>
>     *www.creaf.cat* <http://www.creaf.cat>*| **http://blog.creaf.cat*
>     <http://blog.creaf.cat>
>     https://www.creaf.cat/sites/default/files/uab_logo_signatura.png
>     CREAF. Campus UAB. Edifici C. 08193 Bellaterra (Barcelona)
>     Before printing this electronic message, think about the environment.
>     http://www.creaf.uab.cat/_signatura/line.gif
>     _______________________________________________
>     gdal-dev mailing list
>     https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240226/21dcd46c/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240226/21dcd46c/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240226/21dcd46c/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240226/21dcd46c/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240226/21dcd46c/attachment-0009.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240226/21dcd46c/attachment-0010.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240226/21dcd46c/attachment-0011.png>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240226/21dcd46c/attachment-0002.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240226/21dcd46c/attachment-0003.jpg>
