[gdal-dev] Error when importing GeoPackage into PostgreSQL database ("Worker thread task has not expected m_iStartShapeId value")
Even Rouault even.rouault at spatialys.com
Tue Jan 2 06:57:58 PST 2024
Leo,
could you provide your GeoPackage file and the layer you're converting ?
(privately possibly)
Even
Le 02/01/2024 à 15:09, Leo Fuhrmann via gdal-dev a écrit :
> Hi,
> I’m using ogr2ogr 3.8.2 to import a (layer of a) GeoPackage into a
> PostGIS database:
> ogr2ogr --debug ON -f PostgreSQL "PG:dbname=XX host=XX port=XX user=XX
> password=XX” <path/to/gpkg.gpkg> <layer>
> However, I’m seeing an error in the logs that I cannot sort out (see
> mail subject and/or logs below). Despite the error, the data gets
> written to the database, yet I’m worried that something is messed up
> along the way.
> Using the official docker image to execute the command (from a MacBook
> with M1 Pro) works without an error. Then again, using a cloud service
> (IBM Code Engine in this case) with the official image also throws the
> error. I tried with different image versions but found no difference.
> I tried to track down the error and found
> https://github.com/OSGeo/gdal/blob/1df855eb676e17278c337e9b14774d1bb298df90/ogr/ogrsf_frmts/gpkg/ogrgeopackagetablelayer.cpp#L8352
> The comment suggests that I might have messed with GetNextFeature(),
> but I’m sure I haven’t.
> Can someone help me to make sense of this error? I’m sorry to say that
> I can’t share the GeoPackage at the moment.
> Thanks, Leo
> Here are the logs:
> GPKG: GeoPackage v1.2.0
> GDAL: GDALOpen(<path/to/gpkg.gpkg>, this=0x14c053e00) succeeds as GPKG.
> GDAL: GDALDriver::Create(PostgreSQL,PG:dbname=XX host=XX port=XX
> user=XX password=XX
> PG: Client encoding: 'UTF8'
> PG: PostGIS schema: 'public'
> PG: PostgreSQL version string : 'PostgreSQL 16.1 (Debian
> 16.1-1.pgdg110+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian
> 10.2.1-6) 10.2.1 20210110, 64-bit'
> PG: PostGIS version string : '3.4 USE_GEOS=1 USE_PROJ=1 USE_STATS=1'
> PG: Could not retrieve table oid for <layer>
> GDALVectorTranslate: Using FID=fid and -preserve_fid
> OGR2OGR: Using WriteArrowBatch()
> ERROR 1: Worker thread task has not expected m_iStartShapeId value
> PG: PQputCopyEnd()
> GDAL: GDALClose(<path/to/gpkg.gpkg>, this=0x14c053e00)
> GDAL: GDALClose(PG:dbname=XX host=XX port=XX user=XX password=XX
> this=0x14b721fb0)
> GDAL: In GDALDestroy - unloading GDAL shared library.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240102/4ae09521/attachment.htm>
