[gdal-dev] gdaladdo does not "respect" GPKG tile matrix
Philippe Ghesquiere philippe.ghesquiere at airbus.com
Mon Jan 8 05:24:19 PST 2024
Hi Even,
This is great news ! I will check it out as soon as I can.
Thanks
Philippe
On Mon, Jan 8, 2024 at 1:07 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi Philippe,
> I no longer reproduce the below issues nor
> https://github.com/OSGeo/gdal/issues/3853 with gdaladdo without explicit
> level with GDAL master 3.9dev. This is due to improvement
> https://github.com/OSGeo/gdal/commit/d178b03e3db that reuse existing
> overview levels when they are declared by the dataset. Which is the case
> for a GeoPackage created with a tiling_scheme and with unpopulated levels.
> The only case now where the tiling scheme might no longer be respected is
> if the user specifies an overview level beyond the base one, or some
> "weird" factor like 3. But as it is the user that requests that, I don't
> think we should do anything for that case.
> Even
> Le 08/01/2024 à 11:57, Philippe Ghesquiere via gdal-dev a écrit :
> Dear all,
>  A while ago, I opened a ticket which is still opened (
> https://github.com/OSGeo/gdal/issues/3853). I recently  bumped into this
> bug with some new data, and I think I tracked the origin.
> *1) Generate a test image :*
> gdal_create -of GTIFF -co COMPRESS=LZW -a_srs epsg:4326 -a_ullr -180 90
> 180 -90 -burn 128 -outsize 2048 1024 worldwide.tif
> *2) Convert to GPKG :*
>  gdal_translate -of GPKG -co TILING_SCHEME=InspireCRS84Quad worldwide.tif
> worldwide_no_pyramid.gpkg
> The GPKG tile matrix is as expected :
> sqlite3 -header -column worldwide_no_pyramid.gpkg "SELECT rowid,* FROM
> gpkg_tile_matrix  ;"
> rowid  table_name            zoom_level  matrix_width  matrix_height
>  tile_width  tile_height  pixel_x_size  pixel_y_size
> 1      worldwide_no_pyramid  0           2             1              256
>         256          0.703125      0.703125
> 2      worldwide_no_pyramid  1           4             2              256
>         256          0.3515625     0.3515625
> 3      worldwide_no_pyramid  2           8             4              256
>         256          0.17578125    0.17578125
> *3) Compute a default pyramid:*
> cp worldwide_no_pyramid.gpkg worldwide_default_pyramid.gpkg
> gdaladdo worldwide_default_pyramid.gpkg
> The GPKG tile matrix is no longer the expected one (InspireCRS84Quad
> InspireCRS84Quad) :
> sqlite3 -header -column worldwide_default_pyramid.gpkg  "SELECT rowid,*
> FROM gpkg_tile_matrix  ;"
> 1      worldwide_no_pyramid  1           2             1              256
> 2      worldwide_no_pyramid  2           4             2              256
> 3      worldwide_no_pyramid  3           8             4              256
> 4      worldwide_no_pyramid  0           1             1              256
>         256          1.40625       1.40625
> *4) Compute a manual pyramid:*
> cp worldwide_no_pyramid.gpkg worldwide_manual_pyramid.gpkg
> gdaladdo worldwide_manual_pyramid.gpkg 2 4
> The GPKG tile matrix is still as expected (InspireCRS84Quad
> InspireCRS84Quad) :
> sqlite3 -header -column worldwide_manual_pyramid.gpkg  "SELECT rowid,*
> *5) Compute a "Weird" pyramid:*
> In this test, I generate too many levels in the pyramid on purpose :
> cp worldwide_no_pyramid.gpkg worldwide_manual_weird_pyramid.gpkg
> gdaladdo worldwide_manual_weird_pyramid.gpkg 2 4 8
> The GPKG tile matrix is exactly the same as in
> worldwide_default_pyramid.gpkg :
> sqlite3 -header -column worldwide_manual_weird_pyramid.gpkg  "SELECT
> rowid,* FROM gpkg_tile_matrix  ;"
>         256          1.40625       1.40625
> *6) Conclusion *
> The default power-of-two factor list is computed in gdaladdo.cpp. At this
> point, the algorithm is not aware of some GPKG limitations.
> I found two workarounds :
>    - specify explicitly all zoom levels
>    - add minsize option. The minimum size has to be twice the tile_height
>    / tile_width : -minsize 512
> Shouldn't we have a specific check for GPKG while computing the pyramid ?
> For example by deriving the virtual method BuildOverviews() for GPKG ?
> Philippe
> The information in this e-mail is confidential. The contents may not be
> disclosed or used by anyone other than the addressee. Access to this e-mail
> by anyone else is unauthorised.
> If you are not the intended recipient, please notify Airbus immediately
> and delete this e-mail.
> Airbus cannot accept any responsibility for the accuracy or completeness
> of this e-mail as it has been sent over public networks. If you have any
> concerns over the content of this message or its Accuracy or Integrity,
> please contact Airbus immediately.
> All outgoing e-mails from Airbus are checked using regularly updated virus
> scanning software but you should take whatever measures you deem to be
> appropriate to ensure that this message and any attachments are virus free.
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
The information in this e-mail is confidential. The contents may not be disclosed or used by anyone other than the addressee. Access to this e-mail by anyone else is unauthorised.
If you are not the intended recipient, please notify Airbus immediately and delete this e-mail.
Airbus cannot accept any responsibility for the accuracy or completeness of this e-mail as it has been sent over public networks. If you have any concerns over the content of this message or its Accuracy or Integrity, please contact Airbus immediately.
All outgoing e-mails from Airbus are checked using regularly updated virus scanning software but you should take whatever measures you deem to be appropriate to ensure that this message and any attachments are virus free.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240108/8719573f/attachment-0001.htm>
