[gdal-dev] Nearblack and the datatype of the output
Even Rouault even.rouault at spatialys.com
Fri Jan 12 08:05:14 PST 2024
Jukka,
nearblack is quite a special case. The doc says "The processing is all
done in 8bit (Bytes)." , so it only properly works on Byte datasets.. If
you provide any other data type, the values will be clamped to [0,255].
And when creating an output file, it will always be Byte.
The data type is not technically a "creation option" (in the sense of
the -co option). It is an argument of the GDALDriver::Create() function
(which takes creation options as well)
Even
Le 12/01/2024 à 14:39, Rahkonen Jukka via gdal-dev a écrit :
> Hi,
> Do I understand right that the raster drivers like the GTiff driver do
> not have a creation option for the datatype? Most utilities like
> gdal_translate, gdalwarp, and gdal_create have the -ot option, but
> there are couple of utilities that don’t even it might make sense. For
> example nearblack can only create float32 output from float32 input
> and user cannot do anything for that.
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240112/86b9ffa7/attachment.htm>
