[gdal-dev] Error building GDAL 3.8.3: Installed GEOS not found during build
Eric Patton eric.r.patton at pm.me
Tue Jan 16 08:20:40 PST 2024
I am running into an error while building gdal 3.8.3 from source - it seems GEOS (version 3.12.1) is not being found during the build, despite that fact it was completely installed from source with no errors. I'm using LInux Mint 20.3.
# GDAL build commands used:
$ cmake -DCMAKE_BUILD_TYPE=Release ..
(No obvious errors in output, GEOS seems to be located):
-- The following RECOMMENDED packages have been found:
* GEOS
Geometry Engine - Open Source (GDAL core dependency)
$ cmake --build .
<snip>
[ 95%] Built target gcore_mdreader
CMakeFiles/GDAL.dir/build.make:2687: *** target pattern contains no '%'. Stop.
make[1]: *** [CMakeFiles/Makefile2:5005: CMakeFiles/GDAL.dir/all] Error 2
make: *** [Makefile:141: all] Error 2
# Line 2687 of /usr/local/gdal-3.8.3/build/CMakefiles/GDAL.dir:
libgdal.so.34.3.8.3: GEOS::geos_c-NOTFOUND
# But that's strange:
$ which geos-config
/usr/local/bin/geos-config
$ geos-config --version
3.12.1
# Location of GEOS include dir:
$ cd /usr
$ find . -name "geos_c.h"
./local/geos-3.12.1/_build/capi/geos_c.h
./local/include/geos_c.h
# Location of GEOS_LIBRARY:
$ cd /usr
$ find . -name "*libgeos_c*"
./local/lib/libgeos_c.so.1
./local/lib/libgeos_c.so.1.18.1
./local/geos-3.12.1/_build/lib/libgeos_c.so.1
./local/geos-3.12.1/_build/lib/libgeos_c.so.1.18.1
$ uname -a:
Linux FieldBathy 5.15.0-91-generic #101~20.04.1-Ubuntu SMP Thu Nov 16 14:22:28 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
Please let me know if there's anything else I can post to help diagnose the error, thanks.
Eric Patton
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240116/38cffe9b/attachment.htm>
