[gdal-dev] Where to fins my own files
Even Rouault even.rouault at spatialys.com
Thu Jan 18 12:20:54 PST 2024
Le 18/01/2024 à 21:16, Abel Pau a écrit :
> After all that process if I search for the file in all gdal it appears
> twice:
> d:\GitHub-repository\gdal\ogr\ogrsf_frmts\miramon\data\MM_m_idofic.csv
> <-- OK; where it is...
Yes, this is the location of the source file, as stored in the git
repository and in release source tarballs.
> And here, with all other data files. It is correct?
> d:\GitHub-repository\gdal\build\data\MM_m_idofic.csv
Yes, build artifact copied from source location by the logic at
https://github.com/OSGeo/gdal/blob/a090314330026333eba534d50f74499ffee76d63/gdal.cmake#L671
As I mentioned yesterday, for development builds, you should change your
GDAL_DATA env var now to point to d:\GitHub-repository\gdal\build\data
Even
> *De:*gdal-dev <gdal-dev-bounces at lists.osgeo.org> *En nombre de *Abel
> Pau via gdal-dev
> *Enviado el:* dijous, 18 de gener de 2024 21:13
> *Para:* Even Rouault <even.rouault at spatialys.com>;
> gdal-dev at lists.osgeo.org
> *Asunto:* Re: [gdal-dev] Where to fins my own files
> Even,
> thanks a lot.
> I moved the file to {my
> GitHubDir}\GDAL\ogr\ogrsf_frmts\miramon\data\MM_m_idofic.csv
> I changed my CMakeLists.txt  (see it below) as you indicated. And I
> deleted from gdal.cmake than now has only 5 files in there)
> I rebased, deleted my gdal\build directory created the project again
> and built this.
> An when I debug it seems that CPLFindFile("gdal",
> "MM_m_idofic.csv");returns NULL. If I see inside it has only one
> locator and it seems that should be more, now...
> I am missing something?
> The CMakeLists
> add_gdal_driver(
> TARGETogr_MiraMon
> SOURCESogrmiramondatasource.cpp ogrmiramondriver.cpp
> ogrmiramonlayer.cpp mm_wrlayr.c mm_gdal_functions.c mmrdlayr.c
> BUILTIN)
> gdal_standard_includes(ogr_MiraMon)
> target_include_directories(ogr_MiraMon
> PRIVATE$<TARGET_PROPERTY:ogrsf_generic,SOURCE_DIR>)
> set(GDAL_DATA_FILES
> *${CMAKE_CURRENT_SOURCE_DIR}*/data/MM_m_idofic.csv
> set_property(
> TARGET*${GDAL_LIB_TARGET_NAME}*
> APPEND
> PROPERTY RESOURCE"*${GDAL_DATA_FILES}*")
> Thanks again
> *De:*Even Rouault <even.rouault at spatialys.com>
> *Enviado el:* dimecres, 17 de gener de 2024 17:13
> *Para:* Abel Pau <a.pau at creaf.uab.cat>; gdal-dev at lists.osgeo.org
> Abel,
> Le 17/01/2024 à 15:50, Abel Pau a écrit :
>     Hi,
>     ok Even,
>     so, as my driver is not already online I have to do some changes
>     at this part of the code, don’t I?
>     At this moment I have the file in the folder GDAL\data (my
>     GDAL_DATA environment variable).
>     I call it like that.
>     aMMIDDBFFile=CPLFindFile("gdal", "MM_m_idofic.csv");
>     Do I have to move the file to somewhere? where?
> I've merged the PR, so you can rebase on top of latest master
> No change required in your .cpp file
> The only change is to move the resource file into a data/ subdirectory
> within your ogr/ogrsf_frmts/XXXX driver directory
> and add in ogr/ogrsf_frmts/XXX/CMakeLists.txt
> set(GDAL_DATA_FILES
>     ${CMAKE_CURRENT_SOURCE_DIR}/data/MM_m_idofic.csv
> set_property(
>   TARGET ${GDAL_LIB_TARGET_NAME}
>   APPEND
>   PROPERTY RESOURCE "${GDAL_DATA_FILES}")
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240118/fc382704/attachment.htm>
