[gdal-dev] gdal2tiles custom tms configuration not found
Andreas Neumann a.neumann at carto.net
Fri Jan 19 04:21:58 PST 2024
Hi Even,
Thank you - that explains it. I will probably switch to some other tools
then - maybe MapProxy. I wanted to use this custom tms configuration
from Swisstopo - to stay compatible with their web services.
Thank you for adding a better error output!
Andreas
On 2024-01-19 13:08, Even Rouault wrote:
> Andreas,
> the reason is that the resolution of some consecutive levels in your
> custom TMS files is not varying by a factor of 2, which gdal2tiles
> doesn't support at the moment (debug message just added in master to
> help diagnose)
> Even
> Le 19/01/2024 à 11:36, Andreas Neumann via gdal-dev a écrit :
>> Hi,
>> I would like to use gdal2tiles with a custom tms profile file. I
>> prepared the json file attached in this mail and put this json file in
>> the /usr/share/gdal folder, there there are already other such files,
>> e.g. from New Zealand or Antartica.
>> However, when I try to use this custon tms config, gdal2tiles tells me
>> it can't find this profile. Here is my command I used:
>> gdal2tiles.py -p 2056_28 -z 16 -w openlayers -t "Swiss Hillshading
>> Grayscale" -r cubic -s EPSG:2056 -a 0.0 -e -n
>> lv_16_switzerland_hillshading_small-scale_swissalti3d-srtm_100m_jpeg.tif
>> tiles
>> Do I need to register the custom TMS config json file somewhere in
>> addition to copying it to the /usr/share/gdal directory?
>> Thank you for your help!
>> Andreas
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240119/f13da1c9/attachment.htm>
