[gdal-dev] units=km not working
Even Rouault even.rouault at spatialys.com
Tue Jan 23 12:11:20 PST 2024
Le 23/01/2024 à 20:56, Wilco K via gdal-dev a écrit :
> Hi,
> why is *units=km* not working?
> *gdaltransform -s_srs EPSG:4326 -t_srs "+proj=stere +lat_0=90 +lon_0=0
> +lat_ts=60 +a=6378.14 +b=6356.75 +x_0=0 +y_0=0 **+units=km" *
> The following error is returned:
> ERROR 1: PROJ: proj_create_operations: Source and target ellipsoid do
> not belong to the same celestial body
> Converting +a and +b to meters and it does works:
> +lat_ts=60 +a=6378140 +b=6356750 +x_0=0 +y_0=0"*
> Any ideas?
Cf https://proj.org/en/9.3/usage/projections.html#units : "Horizontal
coordinate system units can be specified using the |+units| keyword
[...] Note that this does /not/ affect the units of linear parameters
such as |+x_0| or |+y_0| which should always be specified in meters." .
This also applies to the +a and +b parameters. Doc enhancement filed in
https://github.com/OSGeo/PROJ/pull/4010
When you specify +units=km, it just means that you wish the output
projected coordinates are expressed in km. But this doesn't affect the
units of any linear parameters of the projection definition.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240123/7c35aba7/attachment.htm>
