[gdal-dev] Bad values when reading GCPs from a VRT file with gdalinfo in GDAL 3.8.3
Pierluigi Guasqui guasqui at actgate.com
Thu Jan 25 03:34:27 PST 2024
Dear GDAL team,
I am using GDAL version 3.8.3 and I am trying to extract GCPs values with
gdalinfo tool from a VRT file (attached).
As you can see by looking at the VRT file with a text editor GCP XYZ values
are infinite values. When I read GCPs from the attached VRT file with
gdalinfo (latest version GDAL v. 3.8.3) I am getting all zeros:
GCP[  0]: Id=0, Info=
          (0,0) -> (0,0,0)
Instead, if I use gdalinfo (GDAL v. 3.6.3) I am getting the correct values:
          (0,0) -> (inf,inf,-inf)
Is this a bug with GDAL 3.8.3?
Thank you for your help!
Pierluigi Guasqui
Software Engineer
Applied Coherent Technology Corporation (ACT)
www.actgate.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240125/0ed05ccf/attachment-0001.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240125/0ed05ccf/attachment-0001.jpg>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240125/0ed05ccf/attachment-0001.obj>
