[gdal-dev] Bad values when reading GCPs from a VRT file with gdalinfo in GDAL 3.8.3
Rahkonen Jukka jukka.rahkonen at maanmittauslaitos.fi
Thu Jan 25 04:24:54 PST 2024
I guessed so. Is that your own invention or is it documented somewhere that undefined GCPs should be marked that way by using INF? I ask because if it is something that should be reliable then I may have use for that feature in the future.
Problem may be limited to vrt. This test seems to pass
gdal_translate -gcp 0 0 inf inf test.tif inftest.tif
gdalinfo inftest.tif
GCP[  0]: Id=1, Info=
          (0,0) -> (inf,inf,0)
-Jukka Rahkonen-
Lähettäjä: Pierluigi Guasqui <guasqui at actgate.com>
Lähetetty: torstai 25. tammikuuta 2024 14.16
Vastaanottaja: Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
Aihe: Re: [gdal-dev] Bad values when reading GCPs from a VRT file with gdalinfo in GDAL 3.8.3
Hello Jukka,
in general using infinite values is to mark undefined or invalid GCPs.
Pierluigi
On Thu, Jan 25, 2024 at 12:44 PM Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>> wrote:
Out of curiosity, what is the purpose of using inf or -inf as values? Is it to use them as placeholders telling that you do not know yet what the georeferenced coordinates of the ground control points are?
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org<mailto:gdal-dev-bounces at lists.osgeo.org>> Puolesta Pierluigi Guasqui via gdal-dev
Lähetetty: torstai 25. tammikuuta 2024 13.34
Vastaanottaja: gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Aihe: [gdal-dev] Bad values when reading GCPs from a VRT file with gdalinfo in GDAL 3.8.3
Dear GDAL team,
I am using GDAL version 3.8.3 and I am trying to extract GCPs values with gdalinfo tool from a VRT file (attached).
As you can see by looking at the VRT file with a text editor GCP XYZ values are infinite values. When I read GCPs from the attached VRT file with gdalinfo (latest version GDAL v. 3.8.3) I am getting all zeros:
GCP[  0]: Id=0, Info=
          (0,0) -> (0,0,0)
Instead, if I use gdalinfo (GDAL v. 3.6.3) I am getting the correct values:
          (0,0) -> (inf,inf,-inf)
Is this a bug with GDAL 3.8.3?
Thank you for your help!
Pierluigi Guasqui
Software Engineer
Applied Coherent Technology Corporation (ACT)
www.actgate.com<http://www.actgate.com/>
Pierluigi Guasqui
Software Engineer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240125/284bab2e/attachment.htm>
