[gdal-dev] Passing Python PixelFunctionArguments or kwargs from command line?
Even Rouault even.rouault at spatialys.com
Mon Jan 29 02:54:50 PST 2024
no, the values of pixel function arguments are hardcoded in the VRT.
If someone wanted to implement what you mention, that should rather be
done as open option (-oo) of the VRT driver
Even
Le 29/01/2024 à 08:29, Scott via gdal-dev a écrit :
> With a python pixel function in a .vrt file, is it possible to pass
> values from the command line?
> Example:
> gdal_translate ... -lco PixelFunctionArguments=? or -lco -kwargs=?
> Basically I want to change the 'min' and 'max' values on the command
> line:
> <PixelFunctionArguments min="0" max="100" />
> Thanks!
> Scott
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
