[gdal-dev] Lost error messages
Even Rouault even.rouault at spatialys.com
Tue Jan 30 03:26:09 PST 2024
Ray,
Le 30/01/2024 à 05:43, Ray at Daylon via gdal-dev a écrit :
> I was tracing through the TIGER/Line OGR driver and noticed that
> it calls OGRTigerDataSource::Open with the bTestOpen parameter
> set to TRUE, causing that function to skip calling CPLError
> and only return FALSE if an error happens.
> This causes an interesting situation: an app can have the TIGER driver
> fail, but not be told why. Calling CPLGetLastErrorXXX doesn't help
> because no error condition was formally reported.
> Is there a reason why bTestOpen is set to TRUE? Shouldn't
> full error reporting be the default? If this parameter is
> important, shouldn't it be part of the driver API so an app
> can set it to get errors described?
I presume this is mostly a copy&paste pattern borrowed from the
Shapefile driver. Basically the reason to be silent in most situations
is that the Tiger driver opens a directory, and there's no easy way to
know in advance if a directory belongs to the Tiger driver, or the
Shapefile one, or the MITAB one, or etc.. than iterating over its files
and checking if they have  extensions that look like a Tiger dataset. So
failure of finding such file shouldn't trigger a verbose error,
otherwise this would prevent other drivers to also try checking if they
recognize the content of the directory.
And congratulations: you're the first user in recent times I'm aware of
to have interest in that driver ;-) Or perhaps that was just accidental?
Even
http://www.spatialys.com
