[gdal-dev] When use GDALInfo.exe to open a large size BMP file, Error 4 comes
Even Rouault even.rouault at spatialys.com
Wed Jan 31 03:42:10 PST 2024
nothing suspicious from a quick look, but I must confess I'm not
BMP-header-decoding-from-hex-string fluent, so I might have missed
something. It would help if you could extract the first kilobyte of the
file and attach it
Even
Le 31/01/2024 à 12:28, zrh via gdal-dev a écrit :
> Hi, everyone,
> I have 2 BMP files, huge size:
> The first one:
> E:\w8.bmp,   size=12,884,901,942 bytes
> the file header:
> 42 4D 00 00 00 00 00 00 00 00 36 00 00 00 28 00 00 00 00 00 01 00 00 00 01 00 01 00 18 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
> The second one:
> E:\w9.bmp, size=51,438,944,310 bytes
> the file header:
> 42 4D 00 00 00 00 00 00 00 00 36 00 00 00 28 00 00 00 00 FF 01 00 00 00 02 00 01 00 18 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
> My problem is:
> When I run Gdalinfo.exe:
> C:\OSGeo4W\bin>gdalinfo E:\w8.bmp
> ERROR 4: `E:\w8.bmp' not recognized as a supported file format.
> gdalinfo failed - unable to open 'E:\w8.bmp'.
> But E:\w9.bmp is OK.
> Why? Please help!
> Best regards,
> zrh
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
