[gdal-dev] Unknown projection
Even Rouault even.rouault at spatialys.com
Wed Jan 31 11:54:30 PST 2024
Matt,
surprisingly or not, the GTiff driver doesn't try to get the SRS from a
.prj side car file.
So just do
gdal_edit.py 047_0001.tif -a_srs "$(cat 047_0001.prj)"
Even
Le 31/01/2024 à 20:22, Matt.Wilkie via gdal-dev a écrit :
> Hello gdal,
> I have a collection of aerial photos for which neither gdal nor arc
> pro recognize the projection. To my eye the .prj files look ok.
> Attached txt is gdalinfo v3.8.0 report along with the .prj. I manually
> formatted the below for readability:
> PROJCS["UTM_07N",
>     GEOGCS["NAD83-CSRS Epoch 2006 (7 Param+Vel)",
>         DATUM["NAD83-CSRS Epoch 2006 (7 Param+Vel)",
>             SPHEROID["GRS 80", 6378137,298.2572221010002],
>             TOWGS84[1.0026,-1.9083,-0.5165, 1.288877171229702e-07,
> 8.998141921392988e-09, 5.376098909823645e-08, -1.18e-09]],
>         PRIMEM["Greenwich",0],
>         UNIT["degree",0.0174532925199433]
>     PROJECTION["Transverse_Mercator"],
>     PARAMETER["latitude_of_origin",0],
>     PARAMETER["central_meridian",-141],
>     PARAMETER["scale_factor",0.9996],
>     PARAMETER["false_easting",500000],
>     PARAMETER["false_northing",0],
>     UNIT["metres",1]
> Thanks!
> *Matt Wilkie*
> Geomatics Developer & Administrator
> Environment | Technology, Innovation and Mapping
> T 867-667-8133 | _Yukon.ca <http://yukon.ca/>_
> /Hours: 08:30-16:30, Mon-Wed: Office, Thu: Remote, Fri: Away./
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240131/4010b83e/attachment-0001.htm>
