[gdal-dev] GDALWarpOptions vs GDALWarpAppOptions
Fitch, Simeon fitch at astraea.io
Wed Jan 31 13:04:46 PST 2024
Super helpful. I was incorrectly thinking of `GDALWarp` as the lower-level
entrypoint that the other warper calls used, which is where I got confused.
Sounds like `GDALWarp` is basically the entrypoint for the `gdalwarp`
executable, hence the string-oriented API. I should go back and study the
C++ code again.
I'll check out the pythonic binding for further inspiration.
Simeon
On Wed, Jan 31, 2024 at 3:52 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Simeon,
> Le 31/01/2024 à 21:38, Fitch, Simeon via gdal-dev a écrit :
> I'm on the `georust/gdal` bindings team, working on the warp routines, and
> trying to understand the relationship between GDALWarpOptions vs
> GDALWarpAppOptions.
> I'm not seeing any way to create a GDALWarpOptions from a
> GDALWarpAppOptions or vice versa. Are functions needing GDALWarpOptions in
> a completely different universe from ones needing GDALWarpAppOptions?
> Yes. GDALWarpOptions is for the lower level API from gdalwarper.h
> GDALWarpOptions seems clear, with requisite C functions for
> manipulating it, whereas GDALWarpAppOptions seems to only accept key/value
> pairs via GDALWarpAppOptionsSetWarpOption, which seems quite limiting.
> GDALWarpAppOptions is for the higher level gdalwarp C API. Actually most
> of the options are to be provided through the papszArgv parameter of the
> GDALWarpAppOptionsNew() function.  I'm not sure to remember why the
> GDALWarpAppOptionsSetWarpOption() function was added, since it is redundant
> to passing "-wo", "{KEY}={VALUE}" as papszArgv values.
> I recognize that key/value pairs or strings are admittedly not super
> structured, but they are easily extensible in a way that is compatible of a
> stable C API/ABI.
> I was hoping to provide users a single entry point for specifying warp
> options, but wanted some expert advice before going down a dead end.
> I guess both API could be mapped.  GDALWarp() is probably easier for most
> users as it combines different low level methods, like calling
> GDALSuggestedWarpOutput2() to find the target extent and resolution,
> creating the new dataset, etc. If you look at gdalwarp_lib.cpp, you'll find
> there are lots of heuristics there.
> Nothing prevents you to provide a more Rustacean API than the
> string-based one of GDALWarp(). The Python bindings for examples provide a
> way of providing the options as keyword options:
> WarpOptions(options=None, format=None, srcBands=None, dstBands=None,
> outputBounds=None, outputBoundsSRS=None, xRes=None, yRes=None,
> targetAlignedPixels=False, width=0, height=0, srcSRS=None, dstSRS=None,
> coordinateOperation=None, srcAlpha=None, dstAlpha=False, warpOptions=None,
> errorThreshold=None, warpMemoryLimit=None, creationOptions=None,
> outputType=0, workingType=0, resampleAlg=None, srcNodata=None,
> dstNodata=None, multithread=False, tps=False, rpc=False, geoloc=False,
> polynomialOrder=None, transformerOptions=None, cutlineDSName=None,
> cutlineLayer=None, cutlineWhere=None, cutlineSQL=None, cutlineBlend=None,
> cropToCutline=False, copyMetadata=True, metadataConflictValue=None,
> setColorInterpretation=False, overviewLevel='AUTO', callback=None,
> callback_data=None)
>     Create a WarpOptions() object that can be passed to gdal.Warp()
>     Parameters
>     options:
>         can be be an array of strings, a string or let empty and filled
> from other keywords.
>     format:
>         output format ("GTiff", etc...)
>     srcBands:
>         list of source band numbers (between 1 and the number of input
> bands)
>     dstBands:
>         list of output band numbers
>     outputBounds:
>         output bounds as (minX, minY, maxX, maxY) in target SRS
>     outputBoundsSRS:
>         SRS in which output bounds are expressed, in the case they are not
> expressed in dstSRS
>     xRes:
>         output resolution in target SRS
>     yRes:
>     targetAlignedPixels:
>         whether to force output bounds to be multiple of output resolution
>     width:
>         width of the output raster in pixel
>     height:
>         height of the output raster in pixel
>     srcSRS:
>         source SRS
>     dstSRS:
>         output SRS
>     coordinateOperation:
>         coordinate operation as a PROJ string or WKT string
>     srcAlpha:
>         whether to force the last band of the input dataset to be
> considered as an alpha band.
>         If set to False, source alpha warping will be disabled.
>     dstAlpha:
>         whether to force the creation of an output alpha band
>     outputType:
>         output type (gdalconst.GDT_Byte, etc...)
>     workingType:
>         working type (gdalconst.GDT_Byte, etc...)
>     warpOptions:
>         list or dict of warping options
>     errorThreshold:
>         error threshold for approximation transformer (in pixels)
>     warpMemoryLimit:
>         size of working buffer in MB
>     resampleAlg:
>         resampling mode
>     creationOptions:
>         list or dict of creation options
>     srcNodata:
>         source nodata value(s)
>     dstNodata:
>         output nodata value(s)
>     multithread:
>         whether to multithread computation and I/O operations
>     tps:
>         whether to use Thin Plate Spline GCP transformer
>     rpc:
>         whether to use RPC transformer
>     geoloc:
>         whether to use GeoLocation array transformer
>     polynomialOrder:
>         order of polynomial GCP interpolation
>     transformerOptions:
>         list or dict of transformer options
>     cutlineDSName:
>         cutline dataset name
>     cutlineLayer:
>         cutline layer name
>     cutlineWhere:
>         cutline WHERE clause
>     cutlineSQL:
>         cutline SQL statement
>     cutlineBlend:
>         cutline blend distance in pixels
>     cropToCutline:
>         whether to use cutline extent for output bounds
>     copyMetadata:
>         whether to copy source metadata
>     metadataConflictValue:
>         metadata data conflict value
>     setColorInterpretation:
>         whether to force color interpretation of input bands to output
> bands
>     overviewLevel:
>         To specify which overview level of source files must be used
>     callback:
>         callback method
>     callback_data:
>         user data for callback
> Even
> -- http://www.spatialys.com
> My software is free, but my time generally not.
The content of this email is intended for the person or entity to which it
is addressed only. This email may contain confidential information. If you
are not the person to whom this message is addressed, be aware that any
use, reproduction, or distribution of this message is strictly prohibited.
If you received this in error, please contact the sender and immediately
delete this email and any attachments.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240131/29238af1/attachment-0001.htm>
