[gdal-dev] Segmentation fault (core dumped) occurs when running ogr2ogr command on container
寛座 智大 tomohiro.kanza.306 at baycurrent.co.jp
Sun Mar 3 18:30:22 PST 2024
I am implementing batch processing to convert Shape files, publicly available as open data,
into Geojson format within a container environment.
I installed gdal-bin on top of ubuntu:22.04 base image.
The Dockerfile I implemented is as follows:
FROM ubuntu:22.04
ENV DEBIAN_FRONTEND=noninteractive
RUN apt update
RUN apt -y install apt-transport-https jq unzip openjdk-17-jdk-headless curl
# Install gdal-bin
# Reference: https://mothergeo-py.readthedocs.io/en/latest/development/how-to/gdal-ubuntu-pkg.html#how-to-install-gdal-ogr-packages-on-ubuntu
RUN apt -y install software-properties-common
RUN add-apt-repository -y ppa:ubuntugis/ppa
RUN apt update
RUN apt -y install gdal-bin
COPY ./convert.sh /convert.sh
CMD ["bash","convert.sh"]
When executing the ogr2ogr command within convert.sh, the following error occurs:
Shape: DBF Codepage = SJIS for /d1.shp
Shape: Treating as encoding 'MS932'.
GDAL: GDALOpen(/d1.shp, this=0x55f1edd77f30) succeeds as ESRI Shapefile.
GDAL: QuietDelete(/d1_raw.geojson) invoking Delete()
GDAL: GDALDriver::Create(GeoJSON,/d1_raw.geojson,0,0,0,Unknown,(nil))
GDALVectorTranslate: 5315 features written in layer 'd1'
Shape: 5315 features read on layer 'd1'.
GDAL: GDALClose(/d1.shp, this=0x55f1edd77f30)
GDAL: GDALClose(/d1_raw.geojson, this=0x55f1edd75fd0)
GDAL: In GDALDestroy - unloading GDAL shared library.
I checked if convert.sh execution is possible on the VM (host OS running Docker).
The error seems to occur only when executed within the container.
How should I resolve this?
※Environment
Host OS: ubuntu 22.04
Docker Deamon: 25.0.3
gdal-bin: 3.6.4
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240304/7526eac8/attachment.htm>
