[gdal-dev] Alpine, gcc 32-bit in Linux Build Actions
Abel Pau a.pau at creaf.uab.cat
Mon Mar 4 05:59:27 PST 2024
Well,
I've also found that issue: strdup (s=0x0)   Found and corrected.
It's was also a big issue :$
#0  __strlen_avx2 () at ../sysdeps/x86_64/multiarch/strlen-avx2.S:74
#1  0x00007ffff4fa8583 in __GI___strdup (s=0x0) at ./string/strdup.c:41
#2  0x00007ffff6f4c075 in MMInitLayerToRead (hMiraMonLayer=0x5555560b57e0, m_fp=0x555555d5e590,
    pszFilename=0x555555d4f970 "/vsimem/test1067.pol") at /gdal/ogr/ogrsf_frmts/miramon/mm_rdlayr.c:146
#3  0x00007ffff6f2e03a in OGRMiraMonLayer::OGRMiraMonLayer (this=0x555556087b10,
    pszFilename=0x555555d4f970 "/vsimem/test1067.pol", fp=0x0, poSRS=0x0, bUpdateIn=0, papszOpenOptions=0x0,
    MMMap=0x55555607b5c0) at /gdal/ogr/ogrsf_frmts/miramon/ogrmiramonlayer.cpp:219
#4  0x00007ffff6f2c8b5 in OGRMiraMonDataSource::Open (this=0x55555607b460,
    pszFilename=0x555555d4f970 "/vsimem/test1067.pol", fp=0x0, poSRS=0x0, bUpdateIn=0, papszOpenOptionsUsr=0x0)
    at /gdal/ogr/ogrsf_frmts/miramon/ogrmiramondatasource.cpp:71
#5  0x00007ffff6f2d268 in OGRMiraMonDriverOpen (poOpenInfo=0x7fffffffdd00)
    at /gdal/ogr/ogrsf_frmts/miramon/ogrmiramondriver.cpp:87
#6  0x00007ffff73d0819 in GDALDriver::Open (this=0x555555640cb0, poOpenInfo=0x7fffffffdd00, bSetOpenOptions=false)
    at /gdal/gcore/gdaldriver.cpp:116
#7  0x00007ffff73e9980 in GDALOpenEx (pszFilename=0x555555d53d50 "/vsimem/test1067.pol", nOpenFlags=14,
    papszAllowedDrivers=0x0, papszOpenOptions=0x0, papszSiblingFiles=0x0) at /gdal/gcore/gdaldataset.cpp:3745
#8  0x00007ffff73d4be7 in GDALDriver::Delete (this=0x555555640cb0, pszFilename=0x555555d53d50 "/vsimem/test1067.pol")
    at /gdal/gcore/gdaldriver.cpp:1645
#9  0x000055555555e6f0 in TestCreateLayer (poDriver=0x555555640cb0, eGeomType=wkbLineString)
    at /gdal/apps/test_ogrsf.cpp:1017
#10 0x000055555555ef8f in TestCreate (poDriver=0x555555640cb0, bFromAllDrivers=1) at /gdal/apps/test_ogrsf.cpp:1107
#11 0x000055555555bdb2 in ThreadFunctionInternal (psContext=0x7fffffffe400) at /gdal/apps/test_ogrsf.cpp:325
#12 0x000055555555bc71 in ThreadFunction (user_data=0x7fffffffe400) at /gdal/apps/test_ogrsf.cpp:283
#13 0x000055555555bac1 in main (nArgc=2, papszArgv=0x555555645050) at /gdal/apps/test_ogrsf.cpp:233
-----Mensaje original-----
De: gdal-dev <gdal-dev-bounces at lists.osgeo.org> En nombre de Abel Pau via gdal-dev
Enviado el: dilluns, 4 de març de 2024 10:42
Para: Even Rouault <even.rouault at spatialys.com>; gdal-dev at lists.osgeo.org
Asunto: Re: [gdal-dev] Alpine, gcc 32-bit in Linux Build Actions
After some investigations, I've concluded that I was doing two things that I've improved lately:
	1) Addressing a memory leak (in a non-typical case in my previous tests). CORRECTED
	2) I was requesting an amount of memory suitable for ogr2ogr of large layers but not for numerous translations on a machine with limited memory. I've reduced the amount of memory required by /10. And now Alpine 32 bits is in green colour!
There are still some tests to review, but I'm optimistic about submitting a pull request soon!
De: gdal-dev <gdal-dev-bounces at lists.osgeo.org> En nombre de Abel Pau via gdal-dev Enviado el: divendres, 1 de març de 2024 16:18
Yes, I hope it's only  ONE single mistake because I have my code very protected against that kind of things...
Before you said that I am using LOG_STR(); from the test and I've filled it in all possible place it could be something.
Remember I have windows and in Visual Studio it works fine...
I don't know how to debug in my Docker linux (only command line) with Cmake compiler...
I think I'll catch the problem. Sooner or later!
I've been there before (years ago with a big problem (not my fault)). Finally I win
De: Even Rouault <even.rouault at spatialys.com> Enviado el: divendres, 1 de març de 2024 16:12
Para: Abel Pau <a.pau at creaf.uab.cat>; gdal-dev at lists.osgeo.org
Your code must be something terrible so that even gdb doesn't catch it
:-) (SIGKILL cannot be caught...)
 From the error messages, things might go wrong starting with
https://github.com/OSGeo/gdal/blob/master/apps/test_ogrsf.cpp#L782
So maybe set a breakpoint at that line
b test_ogrsf.cpp:782
and then use "step", and "next" to single step and locate where this crashes. This is going to be a bit tedious...
(you might also want to modify slightly test_ogrsf so that this
TestCreateLayer() method exists early when !EQUAL(poDriver->GetDescription(), "miramon") to avoid debugging other
drivers)
You might install "ddd", as a GUI front-end for gdb, so that this is slightly more user friendly.
http://www.spatialys.com
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
