[gdal-dev] Testing the driver
    Even Rouault
    even.rouault at spatialys.com
    Wed Mar  6 04:36:07 PST 2024
Le 06/03/2024 à 13:14, Abel Pau a écrit :
> Hi Even,
> I finally discovered the error. It was the fixture. In the wrong place.
> Now I’m creating the test.
> I hope finish it soon.
> On the other hand,
> in my actions tab: Merge branch 'OSGeo:master' into master ·
> AbelPau/gdal at 0249b6d (github.com)
> <https://github.com/AbelPau/gdal/actions/runs/8169099745/job/22332488002>
> There are some tiff failures, but nothing on my hand about tiff.
> ================================== FAILURES
> 36: _____________________________ test_tiff_write_133
> 36:
> 36: def test_tiff_write_133():
> Do you know what it can be?
There are sometimes random failures, but here it fails on both the
build-windows-msys2-mingw and build-windows-conda configs . I would
suspect this might be a side effect of a previous run of the Miramon
driver by another test with an invalid filename such as /foo/bar.
Actually I see that test_ogrsf tries to create a /foo/test file.
And
https://github.com/AbelPau/gdal/blob/master/ogr/ogrsf_frmts/miramon/ogrmiramondatasource.cpp#L219
does a VSIMkdirRecursive(), so it must create a "/foo" directory. I
would recommend against using VSIMkdirRecursive() in a driver. You might
use VSIMkdir() to create the latest level of directory, but creating the
whole hiearchy is granting too much power to a driver.
Even
> *De:*Even Rouault <even.rouault at spatialys.com>
> *Enviado el:* dimecres, 6 de març de 2024 13:09
> *Para:* Abel Pau <a.pau at creaf.uab.cat>; gdal-dev at lists.osgeo.org
> *Asunto:* Re: [gdal-dev] Testing the driver
> Hi,
> I don't see anything wrong. I've tried that on my native Linux build
> and the test_ogr_miramon_vector_1() is found. Does "pytest
> autotest/ogr/ogr_basic_test.py" work?*
> Note: you don't need the try / except in your test case unless you'd
> need to some particular cleanup, but that's not the case here. pytest
> handles test failures nicely
> Even
> Le 05/03/2024 à 22:28, Abel Pau via gdal-dev a écrit :
>     Hi again,
>     after solving some issues I used WSL (Windows subsystem Linux) to
>     create an environment where I am able to run tests.
>     I run the cmake inside build folder in the environment. It’s slow
>     but finally it finish. After cmake --build . --target install all
>     is ready to be tested.
>     I create a simple test ogr_miramon_vector.py (see the code below)
>     to prove that it’s reliable.
>     I run:
>     pytest autotest/ogr/ogr_miramon_vector.py
>     and:
>     apau at ABEL2:/mnt/d/GitHub-repository/gdal/build$ pytest
>     Test session starts (platform: linux, Python 3.8.10, pytest 8.0.2,
>     pytest-sugar 1.0.0)
>     benchmark: 4.0.0 (defaults: timer=time.perf_counter
>     disable_gc=False min_rounds=5 min_time=0.000005 max_time=1.0
>     calibration_precision=10 warmup=False warmup_iterations=100000)
>     GDAL Build Info:
>     PAM_ENABLED: YES
>     OGR_ENABLED: YES
>     CURL_ENABLED: YES
>     CURL_VERSION: 7.68.0
>     GEOS_ENABLED: YES
>     GEOS_VERSION: 3.8.0-CAPI-1.13.1
>     PROJ_BUILD_VERSION: 6.3.1
>     PROJ_RUNTIME_VERSION: 6.3.1
>     COMPILER: GCC 9.4.0
>     GDAL_DOWNLOAD_TEST_DATA: undefined (tests relying on downloaded
>     data may be skipped)
>     GDAL_RUN_SLOW_TESTS: undefined (tests marked as "slow" will be
>     skipped)
>     rootdir: /mnt/d/GitHub-repository/gdal/build/autotest
>     configfile: pytest.ini
>     plugins: benchmark-4.0.0, sugar-1.0.0, env-1.1.3
>     *collected 0 items*
>     My questions is why it seems it’s not working?
>     Thanks!
>     The test:
>     import os
>     import gdaltest
>     import ogrtest
>     import pytest
>     from osgeo import gdal, ogr, osr
>     pytestmark = pytest.mark.require_driver("MiraMonVector")
>     @pytest.fixture(scope="module", autouse=True)
>     def init():
>     with gdaltest.config_option("CPL_DEBUG", "ON"):
>     yield
>     # basic test
>     def test_ogr_miramon_vector_1():
>     try:
>     ds =
>     gdal.OpenEx("data/miramon/Points/SimplePoints/SimplePointsFile.pnt")
>     lyr = ds.GetLayer(0)
>     assert lyr is not None, "Failed to get layer"
>           assert lyr.GetFeatureCount() == 3
>     assert lyr.GetGeomType() == ogr.wkbPoint
>             f = lyr.GetNextFeature()
>     assert f.GetFID() == 0
>     assert f.GetGeometryRef().ExportToWkt() == "POINT (513.49 848.81)"
>     assert f.GetField("ID_GRAFIC") == "0"
>     assert f.GetField("ID_GRAFIC") == "1"
>     assert f.GetField("ID_GRAFIC") == "2"
>     ds = None
>     except Exception as e:
>     pytest.fail(f"Test failed with exception: {e}")
>     <mailto:%3ceven.rouault at spatialys.com%3e>
>     *Enviado el:* divendres, 9 de febrer de 2024 11:48
>     <mailto:a.pau at creaf.uab.cat>; gdal-dev at lists.osgeo.org
>     Abel,
>     Le 09/02/2024 à 10:55, Abel Pau via gdal-dev a écrit :
>         Hi,
>         I am at the lasts steps before pulling a request about the
>         MiraMon driver.
>         I need to write some documentation and formalize the tests.
>         After that, I’ll do the pull request to github.
>     I'd suggest first before issuing the pull request that you push to
>     your fork on github and look at the Actions tab. That will allow
>     you to fix a lot of things on your side, before issuing the PR itself
>         I am a little confused about the testing. I can use pytest or
>         ctest, right? Which is the favourite? Are there any changes
>         from the official documentation?
>     ctest is just the CMake way of launching the test suite. It will
>     execute C++ tests of autotest/cpp directly, and for tests written
>     in python will launch "pytest autotest/XXXXX" for each directory.
>     "ctest --test-dir $build_dir -R autotest_ogr -V"  will just run
>     all the autotest/ogr tests, which can be quite long already.
>     To test your own development, you may have a more pleasant
>     experience by directly running just the tests for your driver with
>     something like "pytest autotest/ogr/ogr_miramon.py"  (be careful
>     on Windows, the content of $build_dir/autotest is copied from
>     $source_dir/autotest each time "cmake" is run, so if you edit your
>     test .py file directly in the build directory, be super careful of
>     not accidentally losing your work, and make sure to copy its
>     content to the source directory first. That's admittedly an
>     annoying point of the current test setup on Windows, compared to
>     Unix where we use symbolic links)
>     after setting the environment to have PYTHONPATH point to
>     something like $build_dir/swig/python/Release or
>     $build_dir/swig/python/Debug (I believe you're on Windows?).  If
>     you look at the first lines output by the above "ctest --test-dir
>     $build_dir -R autotest_ogr -V" invokation, you'll actually see the
>     PYTHONPATH value to specify.
>     You also need to first install pytest and other testing
>     dependencies with: python -m pip install autotest/requirements.txt
>         There is a minimal test to create?
>     A maximal test suite, you mean ;-) You should aim for a
>     "reasonable" coverage of the code you wrote. Aiming to test the
>     nominal code paths of your driver is desirable (testing the error
>     cases generally requires a lot more effort).
>         Can you recommend me some driver that tests things like:
>         1.Read a point/arc/polygon layer from some format (gml,kml,
>         gpckg,..) and assert the number of readed objectes
>         2.Read a point layer and assert some points (3d included) and
>         some of the fields values
>         3.The same with arcs and polygons
>         4.Create some layer from the own format to anothers and
>         compare the results with some “good” results.
>         5.Create multiple layers from one outer format (like gpx) and
>         verify the name of the created files...
>     You don't necessarily need to use other formats. It is actually
>     better if the tests of a format don't depend too much on other
>     formats, to keep things isolated.
>     To test the read part of your driver, add a
>     autotest/ogr/data/miramon directory with *small* test files,
>     ideally at most a few KB each to keep the size of the GDAL
>     repository reasonable, and a few features in each is often enough
>     to unit test, with different type of geometries, attributes, and
>     use the OGR Python API to open the file and iterate over its
>     layers and features to check their content. Those files should
>     have ideally be produced by the Miramon software and not by the
>     writing side of your driver, to check the interoperability of your
>     driver with a "reference" software.
>     For the write site of the driver, you can for example run
>     gdal.VectorTranslate(dest, source) on those files, and use again
>     the test function to validate that the read side of your driver
>     likes what the write site has produced. An alternative is also to
>     do a binary comparison of the file generated by your driver with a
>     reference test file stored in for example
>     autotest/ogr/data/miramon/ref_output. But this may be sometimes a
>     fragile approach if the output of your driver might change in the
>     future (would require regenerating the reference test files).
>     I'd suggest your test suite also has a test that runs the
>     "test_ogrsf" command line utility which is a kind of compliance
>     test suite which checks a number of expectations for a driver,
>     like that GetFeatureCount() returns the same number as iterating
>     with GetNextFeature(), etc etc
>     It is difficult to point at a "reference" test suite, as all
>     drivers have their particularities and may need specific tests.
>     Potential sources of inspirations:
>     - autotest/ogr/ogr_gtfs.py  . Shows very simple testing of the
>     read side of a driver, and includes a test_ogrsf test
>     - autotest/ogr/ogr_csv.py  has examples where the writing side of
>     the driver is checked by opening the output file and checking that
>     some strings are present in it (only easily doable with text based
>     formats)
>     - autotest/ogr/ogr_openfilegdb_write.py . Extensive testing of the
>     writing side of a driver . A lot in it will be specific to the
>     format and irrelevant to your concern, but you should at least
>     find all possible aspects of how to test the write side of a driver.
>     Even
>     http://www.spatialys.com
>     My software is free, but my time generally not.
>     _______________________________________________
>     gdal-dev mailing list
>     https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240306/c8e6a748/attachment-0001.htm>
