[gdal-dev] Testing the driver
Even Rouault even.rouault at spatialys.com
Wed Mar 6 08:11:38 PST 2024
PYTHONMALLOC=malloc gdb --args python3 -m pytest
autotest/ogr/ogr_miramon_vector.py
PYTHONMALLOC=malloc valgrind python3 -m pytest
Le 06/03/2024 à 16:02, Abel Pau via gdal-dev a écrit :
> Hi again,
> anyone have any advice for debuging into python code?
> I am using Pdb but it’s a little confusing.
> Any experience?
> Thanks
> apau at ABEL2:/mnt/d/GitHub-repository/gdal/build$ pytest
> Test session starts (platform: linux, Python 3.8.10, pytest 8.0.2,
> pytest-sugar 1.0.0)
> benchmark: 4.0.0 (defaults: timer=time.perf_counter disable_gc=False
> min_rounds=5 min_time=0.000005 max_time=1.0 calibration_precision=10
> warmup=False warmup_iterations=100000)
> GDAL Build Info:
> PAM_ENABLED: YES
> OGR_ENABLED: YES
> CURL_ENABLED: YES
> CURL_VERSION: 7.68.0
> GEOS_ENABLED: YES
> GEOS_VERSION: 3.8.0-CAPI-1.13.1
> PROJ_BUILD_VERSION: 6.3.1
> PROJ_RUNTIME_VERSION: 6.3.1
> COMPILER: GCC 9.4.0
> GDAL_DOWNLOAD_TEST_DATA: undefined (tests relying on downloaded data
> may be skipped)
> GDAL_RUN_SLOW_TESTS: undefined (tests marked as "slow" will be skipped)
> rootdir: /mnt/d/GitHub-repository/gdal/build/autotest
> configfile: pytest.ini
> plugins: benchmark-4.0.0, sugar-1.0.0, env-1.1.3
> collected 3 items
> ✓✓        67%██████▋
> >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> PDB set_trace (IO-capturing turned off)
> > /mnt/d/GitHub-repository/gdal/build/autotest/ogr/ogr_miramon_vector.py(132)test_ogr_miramon_simple_polygon()
> -> f = lyr.GetNextFeature()
> (Pdb) s
> --Call--
> > /mnt/d/GitHub-repository/gdal/build/swig/python/osgeo/ogr.py(1654)GetNextFeature()
> -> def GetNextFeature(self, *args) -> "OGRFeatureShadow *":
> (Pdb) s
> > /mnt/d/GitHub-repository/gdal/build/swig/python/osgeo/ogr.py(1668)GetNextFeature()
> -> return _ogr.Layer_GetNextFeature(self, *args)
> (Pdb) s
> ERROR 2: CPLRealloc(): Out of memory allocating 667227037326010464 bytes.
> Fatal Python error: Aborted
> Current thread 0x00007f67c7140740 (most recent call first):
> File "/mnt/d/GitHub-repository/gdal/build/swig/python/osgeo/ogr.py",
> line 1668 in GetNextFeature
> File
> "/mnt/d/GitHub-repository/gdal/build/autotest/ogr/ogr_miramon_vector.py",
> line 132 in test_ogr_miramon_simple_polygon
> File "/usr/local/lib/python3.8/dist-packages/_pytest/python.py", line
> 194 in pytest_pyfunc_call
> File "/usr/local/lib/python3.8/dist-packages/pluggy/_callers.py", line
> 102 in _multicall
> File "/usr/local/lib/python3.8/dist-packages/pluggy/_manager.py", line
> 119 in _hookexec
> File "/usr/local/lib/python3.8/dist-packages/pluggy/_hooks.py", line
> 501 in __call__
> 1831 in runtest
> File "/usr/local/lib/python3.8/dist-packages/_pytest/runner.py", line
> 170 in pytest_runtest_call
> 102 in _multicall
> 119 in _hookexec
> 501 in __call__
> 263 in <lambda>
> 342 in from_call
> 262 in call_runtest_hook
> 223 in call_and_report
> 134 in runtestprotocol
> 115 in pytest_runtest_protocol
> 102 in _multicall
> 119 in _hookexec
> 501 in __call__
> File "/usr/local/lib/python3.8/dist-packages/_pytest/main.py", line
> 352 in pytest_runtestloop
> 102 in _multicall
> 119 in _hookexec
> 501 in __call__
> 327 in _main
> 273 in wrap_session
> 320 in pytest_cmdline_main
> 102 in _multicall
> 119 in _hookexec
> 501 in __call__
> File
> "/usr/local/lib/python3.8/dist-packages/_pytest/config/__init__.py",
> line 175 in main
> File
> line 198 in console_main
> File "/usr/local/bin/pytest", line 8 in <module>
> Aborted
> *De:*gdal-dev <gdal-dev-bounces at lists.osgeo.org> *En nombre de *Abel
> Pau via gdal-dev
> *Enviado el:* dimecres, 6 de març de 2024 15:08
> *Para:* Even Rouault <even.rouault at spatialys.com>;
> gdal-dev at lists.osgeo.org
> *Asunto:* Re: [gdal-dev] Testing the driver
> About the question: . Does "pytest autotest/ogr/ogr_basic_test.py" work?*
> The answer is YES.
> ✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓✓100%
> Results (5.98s):
> 66 passed
> *De:*Even Rouault <even.rouault at spatialys.com>
> *Enviado el:* dimecres, 6 de març de 2024 13:09
> *Para:* Abel Pau <a.pau at creaf.uab.cat>; gdal-dev at lists.osgeo.org
> Hi,
> I don't see anything wrong. I've tried that on my native Linux build
> and the test_ogr_miramon_vector_1() is found. Does "pytest
> Note: you don't need the try / except in your test case unless you'd
> need to some particular cleanup, but that's not the case here. pytest
> handles test failures nicely
> Even
> Le 05/03/2024 à 22:28, Abel Pau via gdal-dev a écrit :
>     Hi again,
>     after solving some issues I used WSL (Windows subsystem Linux) to
>     create an environment where I am able to run tests.
>     I run the cmake inside build folder in the environment. It’s slow
>     but finally it finish. After cmake --build . --target install all
>     is ready to be tested.
>     I create a simple test ogr_miramon_vector.py (see the code below)
>     to prove that it’s reliable.
>     I run:
>     pytest autotest/ogr/ogr_miramon_vector.py
>     and:
>     pytest-sugar 1.0.0)
>     disable_gc=False min_rounds=5 min_time=0.000005 max_time=1.0
>     calibration_precision=10 warmup=False warmup_iterations=100000)
>     GDAL Build Info:
>     PAM_ENABLED: YES
>     OGR_ENABLED: YES
>     CURL_ENABLED: YES
>     GEOS_ENABLED: YES
>     COMPILER: GCC 9.4.0
>     data may be skipped)
>     skipped)
>     *collected 0 items*
>     My questions is why it seems it’s not working?
>     Thanks!
>     The test:
>     import os
>     import gdaltest
>     import ogrtest
>     import pytest
>     from osgeo import gdal, ogr, osr
>     pytestmark = pytest.mark.require_driver("MiraMonVector")
>     @pytest.fixture(scope="module", autouse=True)
>     def init():
>     with gdaltest.config_option("CPL_DEBUG", "ON"):
>     yield
>     # basic test
>     def test_ogr_miramon_vector_1():
>     try:
>     ds =
>     gdal.OpenEx("data/miramon/Points/SimplePoints/SimplePointsFile.pnt")
>     lyr = ds.GetLayer(0)
>     assert lyr is not None, "Failed to get layer"
>           assert lyr.GetFeatureCount() == 3
>     assert lyr.GetGeomType() == ogr.wkbPoint
>     assert f.GetFID() == 0
>     assert f.GetGeometryRef().ExportToWkt() == "POINT (513.49 848.81)"
>     assert f.GetField("ID_GRAFIC") == "0"
>     assert f.GetField("ID_GRAFIC") == "1"
>     assert f.GetField("ID_GRAFIC") == "2"
>     ds = None
>     except Exception as e:
>     pytest.fail(f"Test failed with exception: {e}")
>     <mailto:even.rouault at spatialys.com>
>     *Enviado el:* divendres, 9 de febrer de 2024 11:48
>     <mailto:a.pau at creaf.uab.cat>; gdal-dev at lists.osgeo.org
>     Abel,
>     Le 09/02/2024 à 10:55, Abel Pau via gdal-dev a écrit :
>         Hi,
>         I am at the lasts steps before pulling a request about the
>         MiraMon driver.
>         I need to write some documentation and formalize the tests.
>         After that, I’ll do the pull request to github.
>     I'd suggest first before issuing the pull request that you push to
>     your fork on github and look at the Actions tab. That will allow
>     you to fix a lot of things on your side, before issuing the PR itself
>         I am a little confused about the testing. I can use pytest or
>         ctest, right? Which is the favourite? Are there any changes
>         from the official documentation?
>     ctest is just the CMake way of launching the test suite. It will
>     execute C++ tests of autotest/cpp directly, and for tests written
>     in python will launch "pytest autotest/XXXXX" for each directory.
>     "ctest --test-dir $build_dir -R autotest_ogr -V"  will just run
>     all the autotest/ogr tests, which can be quite long already.
>     To test your own development, you may have a more pleasant
>     experience by directly running just the tests for your driver with
>     something like "pytest autotest/ogr/ogr_miramon.py"  (be careful
>     on Windows, the content of $build_dir/autotest is copied from
>     $source_dir/autotest each time "cmake" is run, so if you edit your
>     test .py file directly in the build directory, be super careful of
>     not accidentally losing your work, and make sure to copy its
>     content to the source directory first. That's admittedly an
>     annoying point of the current test setup on Windows, compared to
>     Unix where we use symbolic links)
>     after setting the environment to have PYTHONPATH point to
>     something like $build_dir/swig/python/Release or
>     $build_dir/swig/python/Debug (I believe you're on Windows?).  If
>     you look at the first lines output by the above "ctest --test-dir
>     $build_dir -R autotest_ogr -V" invokation, you'll actually see the
>     PYTHONPATH value to specify.
>     You also need to first install pytest and other testing
>     dependencies with: python -m pip install autotest/requirements.txt
>         There is a minimal test to create?
>     A maximal test suite, you mean ;-) You should aim for a
>     "reasonable" coverage of the code you wrote. Aiming to test the
>     nominal code paths of your driver is desirable (testing the error
>     cases generally requires a lot more effort).
>         Can you recommend me some driver that tests things like:
>         1.Read a point/arc/polygon layer from some format (gml,kml,
>         gpckg,..) and assert the number of readed objectes
>         2.Read a point layer and assert some points (3d included) and
>         some of the fields values
>         3.The same with arcs and polygons
>         4.Create some layer from the own format to anothers and
>         compare the results with some “good” results.
>         5.Create multiple layers from one outer format (like gpx) and
>         verify the name of the created files...
>     You don't necessarily need to use other formats. It is actually
>     better if the tests of a format don't depend too much on other
>     formats, to keep things isolated.
>     To test the read part of your driver, add a
>     autotest/ogr/data/miramon directory with *small* test files,
>     ideally at most a few KB each to keep the size of the GDAL
>     repository reasonable, and a few features in each is often enough
>     to unit test, with different type of geometries, attributes, and
>     use the OGR Python API to open the file and iterate over its
>     layers and features to check their content. Those files should
>     have ideally be produced by the Miramon software and not by the
>     writing side of your driver, to check the interoperability of your
>     driver with a "reference" software.
>     For the write site of the driver, you can for example run
>     gdal.VectorTranslate(dest, source) on those files, and use again
>     the test function to validate that the read side of your driver
>     likes what the write site has produced. An alternative is also to
>     do a binary comparison of the file generated by your driver with a
>     reference test file stored in for example
>     autotest/ogr/data/miramon/ref_output. But this may be sometimes a
>     fragile approach if the output of your driver might change in the
>     future (would require regenerating the reference test files).
>     I'd suggest your test suite also has a test that runs the
>     "test_ogrsf" command line utility which is a kind of compliance
>     test suite which checks a number of expectations for a driver,
>     like that GetFeatureCount() returns the same number as iterating
>     with GetNextFeature(), etc etc
>     It is difficult to point at a "reference" test suite, as all
>     drivers have their particularities and may need specific tests.
>     Potential sources of inspirations:
>     - autotest/ogr/ogr_gtfs.py  . Shows very simple testing of the
>     read side of a driver, and includes a test_ogrsf test
>     - autotest/ogr/ogr_csv.py  has examples where the writing side of
>     the driver is checked by opening the output file and checking that
>     some strings are present in it (only easily doable with text based
>     formats)
>     - autotest/ogr/ogr_openfilegdb_write.py . Extensive testing of the
>     writing side of a driver . A lot in it will be specific to the
>     format and irrelevant to your concern, but you should at least
>     find all possible aspects of how to test the write side of a driver.
>     Even
>     http://www.spatialys.com
>     My software is free, but my time generally not.
>     _______________________________________________
>     gdal-dev mailing list
>     https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240306/36890ac8/attachment-0001.htm>
