[gdal-dev] Testing the driver
Daniel Evans daniel.fred.evans at gmail.com
Wed Mar 6 08:59:42 PST 2024
Is it worth moving this in-depth discussion to a PR or similar for the new
driver?
My thinking is that a lengthy discussion on memory leak detection
techniques in C++, how to run tests in Python, etc., aren't topics relevant
to most GDAL mailing list subscribers.
Cheers,
Daniel
On Wed, 6 Mar 2024, 16:54 Abel Pau via gdal-dev, <gdal-dev at lists.osgeo.org>
wrote:
> I was using ubuntu 20.04 and it doesn’t work there.
> Trying to install 22.04 but I have some issues (again).
> *De:* Even Rouault <even.rouault at spatialys.com>
> *Enviado el:* dimecres, 6 de març de 2024 17:12
> *Para:* Abel Pau <a.pau at creaf.uab.cat>; gdal-dev at lists.osgeo.org
> *Asunto:* Re: [gdal-dev] Testing the driver
> PYTHONMALLOC=malloc gdb --args python3 -m pytest
> autotest/ogr/ogr_miramon_vector.py
> PYTHONMALLOC=malloc valgrind python3 -m pytest
> Le 06/03/2024 à 16:02, Abel Pau via gdal-dev a écrit :
> Hi again,
> anyone have any advice for debuging into python code?
> I am using Pdb but it’s a little confusing.
> Any experience?
> Thanks
> apau at ABEL2:/mnt/d/GitHub-repository/gdal/build$ pytest
> Test session starts (platform: linux, Python 3.8.10, pytest 8.0.2,
> pytest-sugar 1.0.0)
> benchmark: 4.0.0 (defaults: timer=time.perf_counter disable_gc=False
> min_rounds=5 min_time=0.000005 max_time=1.0 calibration_precision=10
> warmup=False warmup_iterations=100000)
> GDAL Build Info:
>   PAM_ENABLED: YES
>   OGR_ENABLED: YES
>   CURL_ENABLED: YES
>   CURL_VERSION: 7.68.0
>   GEOS_ENABLED: YES
>   GEOS_VERSION: 3.8.0-CAPI-1.13.1
>   PROJ_BUILD_VERSION: 6.3.1
>   PROJ_RUNTIME_VERSION: 6.3.1
>   COMPILER: GCC 9.4.0
> GDAL_DOWNLOAD_TEST_DATA: undefined (tests relying on downloaded data may
> be skipped)
> GDAL_RUN_SLOW_TESTS: undefined (tests marked as "slow" will be skipped)
> rootdir: /mnt/d/GitHub-repository/gdal/build/autotest
> configfile: pytest.ini
> plugins: benchmark-4.0.0, sugar-1.0.0, env-1.1.3
> collected 3 items
> ogr/ogr_miramon_vector.py ✓✓
>        67%
> PDB set_trace (IO-capturing turned off)
> /mnt/d/GitHub-repository/gdal/build/autotest/ogr/ogr_miramon_vector.py(132)test_ogr_miramon_simple_polygon()
> -> f = lyr.GetNextFeature()
> (Pdb) s
> --Call--
> /mnt/d/GitHub-repository/gdal/build/swig/python/osgeo/ogr.py(1654)GetNextFeature()
> -> def GetNextFeature(self, *args) -> "OGRFeatureShadow *":
> (Pdb) s
> /mnt/d/GitHub-repository/gdal/build/swig/python/osgeo/ogr.py(1668)GetNextFeature()
> -> return _ogr.Layer_GetNextFeature(self, *args)
> (Pdb) s
> ERROR 2: CPLRealloc(): Out of memory allocating 667227037326010464 bytes.
> Fatal Python error: Aborted
> Current thread 0x00007f67c7140740 (most recent call first):
>   File "/mnt/d/GitHub-repository/gdal/build/swig/python/osgeo/ogr.py",
> line 1668 in GetNextFeature
>   File
> "/mnt/d/GitHub-repository/gdal/build/autotest/ogr/ogr_miramon_vector.py",
> line 132 in test_ogr_miramon_simple_polygon
>   File "/usr/local/lib/python3.8/dist-packages/_pytest/python.py", line
> 194 in pytest_pyfunc_call
>   File "/usr/local/lib/python3.8/dist-packages/pluggy/_callers.py", line
> 102 in _multicall
>   File "/usr/local/lib/python3.8/dist-packages/pluggy/_manager.py", line
> 119 in _hookexec
>   File "/usr/local/lib/python3.8/dist-packages/pluggy/_hooks.py", line 501
> in __call__
> 1831 in runtest
>   File "/usr/local/lib/python3.8/dist-packages/_pytest/runner.py", line
> 170 in pytest_runtest_call
> 102 in _multicall
> 119 in _hookexec
> in __call__
> 263 in <lambda>
> 342 in from_call
> 262 in call_runtest_hook
> 223 in call_and_report
> 134 in runtestprotocol
> 115 in pytest_runtest_protocol
> 102 in _multicall
> 119 in _hookexec
> in __call__
>   File "/usr/local/lib/python3.8/dist-packages/_pytest/main.py", line 352
> in pytest_runtestloop
> 102 in _multicall
> 119 in _hookexec
> in __call__
>   File "/usr/local/lib/python3.8/dist-packages/_pytest/main.py", line 327
> in _main
>   File "/usr/local/lib/python3.8/dist-packages/_pytest/main.py", line 273
> in wrap_session
>   File "/usr/local/lib/python3.8/dist-packages/_pytest/main.py", line 320
> in pytest_cmdline_main
> 102 in _multicall
> 119 in _hookexec
> in __call__
>   File
> "/usr/local/lib/python3.8/dist-packages/_pytest/config/__init__.py", line
> 175 in main
>   File
> 198 in console_main
>   File "/usr/local/bin/pytest", line 8 in <module>
> Aborted
> *De:* gdal-dev <gdal-dev-bounces at lists.osgeo.org>
> <gdal-dev-bounces at lists.osgeo.org> *En nombre de *Abel Pau via gdal-dev
> *Enviado el:* dimecres, 6 de març de 2024 15:08
> *Para:* Even Rouault <even.rouault at spatialys.com>
> <even.rouault at spatialys.com>; gdal-dev at lists.osgeo.org
> About the question: . Does "pytest autotest/ogr/ogr_basic_test.py" work?*
> The answer is YES.
> 100% ██████████
> Results (5.98s):
>       66 passed
> *Enviado el:* dimecres, 6 de març de 2024 13:09
> Hi,
> I don't see anything wrong. I've tried that on my native Linux build and
> the test_ogr_miramon_vector_1() is found. Does "pytest
> Note: you don't need the try / except in your test case unless you'd need
> to some particular cleanup, but that's not the case here. pytest handles
> test failures nicely
> Even
> Le 05/03/2024 à 22:28, Abel Pau via gdal-dev a écrit :
> Hi again,
> after solving some issues I used WSL (Windows subsystem Linux) to create
> an environment where I am able to run tests.
> I run the cmake inside build folder in the environment. It’s slow but
> finally it finish. After cmake --build . --target install all is ready to
> be tested.
> I create a simple test ogr_miramon_vector.py (see the code below) to prove
> that it’s reliable.
> I run:
> pytest autotest/ogr/ogr_miramon_vector.py
> and:
> pytest-sugar 1.0.0)
> GDAL Build Info:
>   PAM_ENABLED: YES
>   OGR_ENABLED: YES
>   CURL_ENABLED: YES
>   GEOS_ENABLED: YES
>   COMPILER: GCC 9.4.0
> be skipped)
> *collected 0 items*
> My questions is why it seems it’s not working?
> Thanks!
> The test:
> import os
> import gdaltest
> import ogrtest
> import pytest
> from osgeo import gdal, ogr, osr
> pytestmark = pytest.mark.require_driver("MiraMonVector")
> @pytest.fixture(scope="module", autouse=True)
> def init():
>     with gdaltest.config_option("CPL_DEBUG", "ON"):
>         yield
> # basic test
> def test_ogr_miramon_vector_1():
>     try:
>         ds =
> gdal.OpenEx("data/miramon/Points/SimplePoints/SimplePointsFile.pnt")
>         lyr = ds.GetLayer(0)
>         assert lyr is not None, "Failed to get layer"
>         assert lyr.GetFeatureCount() == 3
>         assert lyr.GetGeomType() == ogr.wkbPoint
>         assert f.GetFID() == 0
>         assert f.GetGeometryRef().ExportToWkt() == "POINT (513.49 848.81)"
>         assert f.GetField("ID_GRAFIC") == "0"
>         assert f.GetField("ID_GRAFIC") == "1"
>         assert f.GetField("ID_GRAFIC") == "2"
>         ds = None
>     except Exception as e:
>         pytest.fail(f"Test failed with exception: {e}")
> *Enviado el:* divendres, 9 de febrer de 2024 11:48
> *Para:* Abel Pau <a.pau at creaf.uab.cat> <a.pau at creaf.uab.cat>;
> Abel,
> Le 09/02/2024 à 10:55, Abel Pau via gdal-dev a écrit :
> Hi,
> I am at the lasts steps before pulling a request about the MiraMon driver.
> I need to write some documentation and formalize the tests.
> After that, I’ll do the pull request to github.
> I'd suggest first before issuing the pull request that you push to your
> fork on github and look at the Actions tab. That will allow you to fix a
> lot of things on your side, before issuing the PR itself
> I am a little confused about the testing. I can use pytest or ctest,
> right? Which is the favourite? Are there any changes from the official
> documentation?
> ctest is just the CMake way of launching the test suite. It will execute
> C++ tests of autotest/cpp directly, and for tests written in python will
> launch "pytest autotest/XXXXX" for each directory.
> "ctest --test-dir $build_dir -R autotest_ogr -V"  will just run all the
> autotest/ogr tests, which can be quite long already.
> To test your own development, you may have a more pleasant experience by
> directly running just the tests for your driver with something like "pytest
> autotest/ogr/ogr_miramon.py"  (be careful on Windows, the content of
> $build_dir/autotest is copied from $source_dir/autotest each time "cmake"
> is run, so if you edit your test .py file directly in the build directory,
> be super careful of not accidentally losing your work, and make sure to
> copy its content to the source directory first. That's admittedly an
> annoying point of the current test setup on Windows, compared to Unix where
> we use symbolic links)
> after setting the environment to have PYTHONPATH point to something like
> $build_dir/swig/python/Release or $build_dir/swig/python/Debug (I believe
> you're on Windows?).  If you look at the first lines output by the above
> "ctest --test-dir $build_dir -R autotest_ogr -V" invokation, you'll
> actually see the PYTHONPATH value to specify.
> You also need to first install pytest and other testing dependencies with:
> python -m pip install autotest/requirements.txt
> There is a minimal test to create?
> A maximal test suite, you mean ;-) You should aim for a "reasonable"
> coverage of the code you wrote. Aiming to test the nominal code paths of
> your driver is desirable (testing the error cases generally requires a lot
> more effort).
> Can you recommend me some driver that tests things like:
> 1.       Read a point/arc/polygon layer from some format (gml,kml,
> gpckg,..) and assert the number of readed objectes
> 2.       Read a point layer and assert some points (3d included) and some
> of the fields values
> 3.       The same with arcs and polygons
> 4.       Create some layer from the own format to anothers and compare
> the results with some “good” results.
> 5.       Create multiple layers from one outer format (like gpx) and
> verify the name of the created files...
> You don't necessarily need to use other formats. It is actually better if
> the tests of a format don't depend too much on other formats, to keep
> things isolated.
> To test the read part of your driver, add a autotest/ogr/data/miramon
> directory with *small* test files, ideally at most a few KB each to keep
> the size of the GDAL repository reasonable, and a few features in each is
> often enough to unit test, with different type of geometries, attributes,
> and use the OGR Python API to open the file and iterate over its layers and
> features to check their content. Those files should have ideally be
> produced by the Miramon software and not by the writing side of your
> driver, to check the interoperability of your driver with a "reference"
> software.
> For the write site of the driver, you can for example run
> gdal.VectorTranslate(dest, source) on those files, and use again the test
> function to validate that the read side of your driver likes what the write
> site has produced. An alternative is also to do a binary comparison of the
> file generated by your driver with a reference test file stored in for
> example autotest/ogr/data/miramon/ref_output. But this may be sometimes a
> fragile approach if the output of your driver might change in the future
> (would require regenerating the reference test files).
> I'd suggest your test suite also has a test that runs the "test_ogrsf"
> command line utility which is a kind of compliance test suite which checks
> a number of expectations for a driver, like that GetFeatureCount() returns
> the same number as iterating with GetNextFeature(), etc etc
> It is difficult to point at a "reference" test suite, as all drivers have
> their particularities and may need specific tests. Potential sources of
> inspirations:
> - autotest/ogr/ogr_gtfs.py  . Shows very simple testing of the read side
> of a driver, and includes a test_ogrsf test
> - autotest/ogr/ogr_csv.py  has examples where the writing side of the
> driver is checked by opening the output file and checking that some strings
> are present in it (only easily doable with text based formats)
> - autotest/ogr/ogr_openfilegdb_write.py . Extensive testing of the writing
> side of a driver . A lot in it will be specific to the format and
> irrelevant to your concern, but you should at least find all possible
> aspects of how to test the write side of a driver.
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240306/6c8a15c0/attachment-0001.htm>
