[gdal-dev] Building on windows
Abel Pau a.pau at creaf.uab.cat
Thu Mar 7 00:41:51 PST 2024
I am a windows and VS2019 user anc C/C++ developer and I asked this question myself a long time ago.
Finally the best way for me was:
1)      Install vcpkg https://vcpkg.io/en/getting-started and install this on c:/dev/vcpkg. Follow their instructions. And then gdal instructions (https://gdal.org/download.html#vcpkg)
a.       git clone https://github.com/Microsoft/vcpkg.git
b.       .\vcpkg\bootstrap-vcpkg.bat
c.       vcpkg integrate install
d.       .\vcpkg install gdal --triplet=x64-windows
2)      Use this line to install all gdal needs: vcpkg --triplet x64-windows install curl expat geos lerc libdeflate libgeotiff libiconv libpng libxml2 openssl proj qhull sqlite3[rtree] xerces-c zlib
3)      Install python using vcpkg: vcpkg install python3
4)      Clone gdal https://github.com/OSGeo/gdal to some directory (let’s call it “$Gdal$”)
5)      Set the system environment variable GDAL_DATA to $Gdal$\build\data
6)      Go to the folder $Gdal$ in cmd and
a.       cmake -B build -S . -DCMAKE_TOOLCHAIN_FILE=C:/dev/vcpkg/vcpkg/scripts/buildsystems/vcpkg.cmake  (<-- look for this file in your vcpkg installation: I have two vcpkg levels, I don’t know why but I don’t care)
b.       cmake --build build
It should work. If it doesn’t, tell us and let’s see if I missed something.
If it’s worth perhaps we can document it in somewhere on gdal page, cause it’s a long journey to set all this. It’s not clear anywhere.
De: gdal-dev <gdal-dev-bounces at lists.osgeo.org> En nombre de Mübin Içyer via gdal-dev
Enviado el: dijous, 7 de març de 2024 8:30
Para: gdal-dev at lists.osgeo.org
Asunto: [gdal-dev] Building on windows
I want to build GDAL on Windows with Visual Studio 17 2022, but I couldn't.
I tried to install all necessary packets with conda but I receive a  lot of errors.
Is there any new tutorial that shows how to build on windows with current and new packets?
Thanks. Regards
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240307/779fe0e2/attachment-0001.htm>
