[gdal-dev] Creating NetCDF dataset with sub datasets
Pierre Chatelier pierre at chachatelier.fr
Thu Mar 7 00:47:24 PST 2024
Hello,
I just had my first encounter with a NetCDF file. GDAL opens that
flawlessly, I can identify the subdatasets and open/read them thanks to
the SUBDATASET_n_NAME, as advertised in
https://gdal.org/drivers/raster/netcdf.html
However, I am confused by the ability to create such a file with GDAL.
Let's say I have a bunch of images that I want to pack as NetCDF through
GDAL.
Should I use bands or groups to let GDAL create the sub datasets ? Will
GDAL create the metadata SUBDATASETS domain for me ?
The NetCDF file I am supposed to create should use HDF for sub datasets.
No problem for reading (I have compiled GDAL with the HDF support and it
works, I can open my sample file), but how do I tell GDAL to *write*
that ? Should I create real datasets with the GDAL HDF driver and then
gather them into a single one with GDAL NetCDF driver ?
Can you give some hints about what I am supposed to do ?
Pierre
