[gdal-dev] Testing the driver
Even Rouault even.rouault at spatialys.com
Thu Mar 7 14:32:19 PST 2024
> At #10 we can see the variable nNum set to a non-sense megabignumber.
Is it on a -DCMAKE_BUILD_TYPE=Debug build ? Otherwise stack traces and
variable content in the debugger might look like garbage because of
optimizations.
If it is a debug build, then there's likely some memory corruption or
uninitialized variable in your code. Valgrind is generally a great tool
to spot that. Otherwise add good old printf() statements to track down
where the corruption starts. And given your Python sample code, I assume
you could more easily reproduce the issue in a pure native context, just
running "ogrinfo -al -q
autotest/ogr/data/miramon/Polygons/SimplePolygons/SimplePolFile.pol" (if
it doesn't crash, try running it under gdb or valgrind)
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240307/33aebeff/attachment.htm>
