[gdal-dev] Testing the driver
Even Rouault even.rouault at spatialys.com
Mon Mar 11 09:55:50 PDT 2024
ok, I've looked a bit at the code
So I believe the issue is that
- https://github.com/OSGeo/gdal/blob/master/apps/test_ogrsf.cpp#L1064
forms a "/foo/test.pol" filename for the miramon driver and call
Create() with it
- and then
https://github.com/AbelPau/gdal/blob/master/ogr/ogrsf_frmts/miramon/ogrmiramondatasource.cpp#L207
"osPath = CPLGetPath(pszRootName);" sets "/foo/" as osPath, which is
then passed to VSIMkdir(), and causing the following mess
I suspect the VSIMkdir() call should only be done in the branch
https://github.com/AbelPau/gdal/blob/master/ogr/ogrsf_frmts/miramon/ogrmiramondatasource.cpp#L211
where pszRootName has an empty extension.
Even
Le 11/03/2024 à 17:30, Abel Pau a écrit :
> Hi,
> going back to the misterious failing test_tiff_write_133 I am not able
> to understand what is wrong with that.
> It seems that it would be failing when writing to an unauthorized
> path. But instead of that it is not failing (and this is the failure,
> not failing when it should fail).
> # Test writing into a non authorized file
> ds = gdaltest.tiff_drv.Create(
>     "/foo/bar", 1024, 1000, 3, options=["STREAMABLE_OUTPUT=YES",
> "BLOCKYSIZE=1"]
> assert ds is None
> So, there is anything I am missing about that?
> The actions that informs that is re-runed in debug mode:
> Merge from base · AbelPau/gdal at 3ec4655 (github.com)
> <https://github.com/AbelPau/gdal/actions/runs/8234751437/job/22520988179>
> FAILED gcore/tiff_write.py::test_tiff_write_133 - AssertionError:
> assert <osgeo.gdal.Dataset; proxy of <Swig Object of type
> 'GDALDatasetShadow *' at 0x0000022226FEDE30> > is None
> It’s not None X-(
> Perhaps I, as Even said, I created a path before? But how to delete
> that? I don’t use anymore: VSIMkdirRecursive(). I use VSIMkdir()
> *Perhaps if the destination folder doesn’t exist I should NOT create
> it and return a FAILURE?*
> *De:*Abel Pau <a.pau at creaf.uab.cat>
> *Enviado el:* dimecres, 6 de març de 2024 16:24
> *Para:* Abel Pau <a.pau at creaf.uab.cat>; Even Rouault
> <even.rouault at spatialys.com>; gdal-dev at lists.osgeo.org
> *Asunto:* RE: [gdal-dev] Testing the driver
> Hi,
> It seems nothing changes. I understand that the environment is new and
> the execution is not related with the last one.
> Here there are 5 tests that fail..
> Any idea of what can be happening?
> They are very unrelated
> Bye VSIMkdirRecursive() · AbelPau/gdal at 646b98b (github.com)
> <https://github.com/AbelPau/gdal/actions/runs/8172351502/job/22342474513>
> *De:*gdal-dev <gdal-dev-bounces at lists.osgeo.org> *En nombre de *Abel
> Pau via gdal-dev
> *Enviado el:* dimecres, 6 de març de 2024 13:52
> *Para:* Even Rouault <even.rouault at spatialys.com>;
> *Asunto:* Re: [gdal-dev] Testing the driver
> Ok, I ‘ve changed that. Let’s see if it’s the problem.
> It’s all so delicate :)
> Thanks again!
> *De:*Even Rouault <even.rouault at spatialys.com>
> *Enviado el:* dimecres, 6 de març de 2024 13:36
> *Para:* Abel Pau <a.pau at creaf.uab.cat>; gdal-dev at lists.osgeo.org
> Le 06/03/2024 à 13:14, Abel Pau a écrit :
>     Hi Even,
>     I finally discovered the error. It was the fixture. In the wrong
>     place.
>     Now I’m creating the test.
>     I hope finish it soon.
>     On the other hand,
>     in my actions tab: Merge branch 'OSGeo:master' into master ·
>     AbelPau/gdal at 0249b6d (github.com)
>     <https://github.com/AbelPau/gdal/actions/runs/8169099745/job/22332488002>
>     There are some tiff failures, but nothing on my hand about tiff.
>     ================================== FAILURES
>     36: _____________________________ test_tiff_write_133
>     36:
>     36: def test_tiff_write_133():
>     Do you know what it can be?
> There are sometimes random failures, but here it fails on both the
> build-windows-msys2-mingw and build-windows-conda configs . I would
> suspect this might be a side effect of a previous run of the Miramon
> driver by another test with an invalid filename such as /foo/bar.
> Actually I see that test_ogrsf tries to create a /foo/test file.
> And
> https://github.com/AbelPau/gdal/blob/master/ogr/ogrsf_frmts/miramon/ogrmiramondatasource.cpp#L219
> does a VSIMkdirRecursive(), so it must create a "/foo" directory. I
> would recommend against using VSIMkdirRecursive() in a driver. You
> might use VSIMkdir() to create the latest level of directory, but
> creating the whole hiearchy is granting too much power to a driver.
> Even
>     <mailto:even.rouault at spatialys.com>
>     *Enviado el:* dimecres, 6 de març de 2024 13:09
>     <mailto:a.pau at creaf.uab.cat>; gdal-dev at lists.osgeo.org
>     Hi,
>     I don't see anything wrong. I've tried that on my native Linux
>     build and the test_ogr_miramon_vector_1() is found. Does "pytest
>     autotest/ogr/ogr_basic_test.py" work?*
>     Note: you don't need the try / except in your test case unless
>     you'd need to some particular cleanup, but that's not the case
>     here. pytest handles test failures nicely
>     Even
>     Le 05/03/2024 à 22:28, Abel Pau via gdal-dev a écrit :
>         Hi again,
>         after solving some issues I used WSL (Windows subsystem Linux)
>         to create an environment where I am able to run tests.
>         I run the cmake inside build folder in the environment. It’s
>         slow but finally it finish. After cmake --build . --target
>         install all is ready to be tested.
>         I create a simple test ogr_miramon_vector.py (see the code
>         below) to prove that it’s reliable.
>         I run:
>         pytest autotest/ogr/ogr_miramon_vector.py
>         and:
>         apau at ABEL2:/mnt/d/GitHub-repository/gdal/build$ pytest
>         Test session starts (platform: linux, Python 3.8.10, pytest
>         8.0.2, pytest-sugar 1.0.0)
>         benchmark: 4.0.0 (defaults: timer=time.perf_counter
>         disable_gc=False min_rounds=5 min_time=0.000005 max_time=1.0
>         calibration_precision=10 warmup=False warmup_iterations=100000)
>         GDAL Build Info:
>           PAM_ENABLED: YES
>           OGR_ENABLED: YES
>           CURL_ENABLED: YES
>           CURL_VERSION: 7.68.0
>           GEOS_ENABLED: YES
>           GEOS_VERSION: 3.8.0-CAPI-1.13.1
>         PROJ_BUILD_VERSION: 6.3.1
>         PROJ_RUNTIME_VERSION: 6.3.1
>           COMPILER: GCC 9.4.0
>         GDAL_DOWNLOAD_TEST_DATA: undefined (tests relying on
>         downloaded data may be skipped)
>         GDAL_RUN_SLOW_TESTS: undefined (tests marked as "slow" will be
>         skipped)
>         rootdir: /mnt/d/GitHub-repository/gdal/build/autotest
>         configfile: pytest.ini
>         plugins: benchmark-4.0.0, sugar-1.0.0, env-1.1.3
>         *collected 0 items*
>         My questions is why it seems it’s not working?
>         Thanks!
>         The test:
>         import os
>         import gdaltest
>         import ogrtest
>         import pytest
>         from osgeo import gdal, ogr, osr
>         pytestmark = pytest.mark.require_driver("MiraMonVector")
>         @pytest.fixture(scope="module", autouse=True)
>         def init():
>             with gdaltest.config_option("CPL_DEBUG", "ON"):
>                 yield
>         # basic test
>         def test_ogr_miramon_vector_1():
>             try:
>                 ds =
>         gdal.OpenEx("data/miramon/Points/SimplePoints/SimplePointsFile.pnt")
>                 lyr = ds.GetLayer(0)
>                 assert lyr is not None, "Failed to get layer"
>                 assert lyr.GetFeatureCount() == 3
>                 assert lyr.GetGeomType() == ogr.wkbPoint
>                 f = lyr.GetNextFeature()
>                 assert f.GetFID() == 0
>                 assert f.GetGeometryRef().ExportToWkt() == "POINT
>         (513.49 848.81)"
>                 assert f.GetField("ID_GRAFIC") == "0"
>                 assert f.GetField("ID_GRAFIC") == "1"
>                 assert f.GetField("ID_GRAFIC") == "2"
>                 ds = None
>             except Exception as e:
>         pytest.fail(f"Test failed with exception: {e}")
>         <mailto:%3ceven.rouault at spatialys.com%3e>
>         *Enviado el:* divendres, 9 de febrer de 2024 11:48
>         Abel,
>         Le 09/02/2024 à 10:55, Abel Pau via gdal-dev a écrit :
>             Hi,
>             I am at the lasts steps before pulling a request about the
>             MiraMon driver.
>             I need to write some documentation and formalize the tests.
>             After that, I’ll do the pull request to github.
>         I'd suggest first before issuing the pull request that you
>         push to your fork on github and look at the Actions tab. That
>         will allow you to fix a lot of things on your side, before
>         issuing the PR itself
>             I am a little confused about the testing. I can use pytest
>             or ctest, right? Which is the favourite? Are there any
>             changes from the official documentation?
>         ctest is just the CMake way of launching the test suite. It
>         will execute C++ tests of autotest/cpp directly, and for tests
>         written in python will launch "pytest autotest/XXXXX" for each
>         directory.
>         "ctest --test-dir $build_dir -R autotest_ogr -V"  will just
>         run all the autotest/ogr tests, which can be quite long already.
>         To test your own development, you may have a more pleasant
>         experience by directly running just the tests for your driver
>         with something like "pytest autotest/ogr/ogr_miramon.py"  (be
>         careful on Windows, the content of $build_dir/autotest is
>         copied from $source_dir/autotest each time "cmake" is run, so
>         if you edit your test .py file directly in the build
>         directory, be super careful of not accidentally losing your
>         work, and make sure to copy its content to the source
>         directory first. That's admittedly an annoying point of the
>         current test setup on Windows, compared to Unix where we use
>         symbolic links)
>         after setting the environment to have PYTHONPATH point to
>         something like $build_dir/swig/python/Release or
>         $build_dir/swig/python/Debug (I believe you're on Windows?).
>         If you look at the first lines output by the above "ctest
>         --test-dir $build_dir -R autotest_ogr -V" invokation, you'll
>         actually see the PYTHONPATH value to specify.
>         You also need to first install pytest and other testing
>         dependencies with: python -m pip install autotest/requirements.txt
>             There is a minimal test to create?
>         A maximal test suite, you mean ;-) You should aim for a
>         "reasonable" coverage of the code you wrote. Aiming to test
>         the nominal code paths of your driver is desirable (testing
>         the error cases generally requires a lot more effort).
>             Can you recommend me some driver that tests things like:
>             1.Read a point/arc/polygon layer from some format
>             (gml,kml, gpckg,..) and assert the number of readed objectes
>             2.Read a point layer and assert some points (3d included)
>             and some of the fields values
>             3.The same with arcs and polygons
>             4.Create some layer from the own format to anothers and
>             compare the results with some “good” results.
>             5.Create multiple layers from one outer format (like gpx)
>             and verify the name of the created files...
>         You don't necessarily need to use other formats. It is
>         actually better if the tests of a format don't depend too much
>         on other formats, to keep things isolated.
>         To test the read part of your driver, add a
>         autotest/ogr/data/miramon directory with *small* test files,
>         ideally at most a few KB each to keep the size of the GDAL
>         repository reasonable, and a few features in each is often
>         enough to unit test, with different type of geometries,
>         attributes, and use the OGR Python API to open the file and
>         iterate over its layers and features to check their content.
>         Those files should have ideally be produced by the Miramon
>         software and not by the writing side of your driver, to check
>         the interoperability of your driver with a "reference" software.
>         For the write site of the driver, you can for example run
>         gdal.VectorTranslate(dest, source) on those files, and use
>         again the test function to validate that the read side of your
>         driver likes what the write site has produced. An alternative
>         is also to do a binary comparison of the file generated by
>         your driver with a reference test file stored in for example
>         autotest/ogr/data/miramon/ref_output. But this may be
>         sometimes a fragile approach if the output of your driver
>         might change in the future (would require regenerating the
>         reference test files).
>         I'd suggest your test suite also has a test that runs the
>         "test_ogrsf" command line utility which is a kind of
>         compliance test suite which checks a number of expectations
>         for a driver, like that GetFeatureCount() returns the same
>         number as iterating with GetNextFeature(), etc etc
>         It is difficult to point at a "reference" test suite, as all
>         drivers have their particularities and may need specific
>         tests. Potential sources of inspirations:
>         - autotest/ogr/ogr_gtfs.py  . Shows very simple testing of the
>         read side of a driver, and includes a test_ogrsf test
>         - autotest/ogr/ogr_csv.py  has examples where the writing side
>         of the driver is checked by opening the output file and
>         checking that some strings are present in it (only easily
>         doable with text based formats)
>         - autotest/ogr/ogr_openfilegdb_write.py . Extensive testing of
>         the writing side of a driver . A lot in it will be specific to
>         the format and irrelevant to your concern, but you should at
>         least find all possible aspects of how to test the write side
>         of a driver.
>         Even
>         http://www.spatialys.com
>         My software is free, but my time generally not.
>         _______________________________________________
>         gdal-dev mailing list
>         https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240311/8ad0c92c/attachment-0001.htm>
