[gdal-dev] Segmentation fault (core dumped) occurs when running ogr2ogr command on container
寛座 智大 tomohiro.kanza.306 at baycurrent.co.jp
Tue Mar 12 01:55:32 PDT 2024
I tried executing with --config CPL_DEBUG ON, but it did not provide any useful information.
I'm sending you the command that's causing the issue.
We're using curl command to obtain the Shape file from the internet.
  1.  Obtaining the Shape file:
$curl -f --output-dir ./ -O https://data.bodik.jp/dataset/d4b9a284-58c0-4559-9e48-b7c83a4275f0/resource/28aa8f13-7cf0-4dc5-9dbf-a77f58c3f2c8/download/shape.zip
  1.  Unzipping the ZIP file:
$unzip -o -j -d ./ ./shape.zip
③ Converting from Shape format to GeoJSON format:
$ogr2ogr -f GeoJSON -oo ENCODING=MS932 ./d1_raw.geojson ./d1.shp --config CPL_DEBUG ON
These commands are executed within the convert.sh called from the Dockerfile.
Best regards,
Sent: Wednesday, March 6, 2024 5:53 PM
To: 寛座 智大 <tomohiro.kanza.306 at baycurrent.co.jp>; gdal-dev at lists.osgeo.org
Subject: RE: Segmentation fault (core dumped) occurs when running ogr2ogr command on container
I reduced the amount of memory requested. I could do that because I am developing the driver that failed.
After my mail I discovered another error, so, perhaps, this was the real cause.
4Mb it’s so small, so I is not the cause...
Perhaps you can add --config  CPL_DEBUG ON at your command line to see if this give you more information about the place where it crashes.
I’m sorry not being able to help you more.
Perhaps you can send me the shape and the command line to see if it crashes in my computer and I can find out the problem.
See you
De: 寛座 智大 <tomohiro.kanza.306 at baycurrent.co.jp<mailto:tomohiro.kanza.306 at baycurrent.co.jp>>
Enviado el: dimecres, 6 de març de 2024 7:20
Para: Abel Pau <a.pau at creaf.uab.cat<mailto:a.pau at creaf.uab.cat>>; gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Asunto: RE: Segmentation fault (core dumped) occurs when running ogr2ogr command on container
Abel Pau,
Hi. Thank you for your response.
>I reduced this capacity 10 times and it worked.
Does this mean you reduced the size of the Shape file?
Or does it mean that you reduced the amount of memory requested?
( If it's the latter, I'd like to learn how to do it.)
Shape files are typically around 4MB, so I don't consider them to be very large files.
Additionally, I tried it on an AKS with a free memory size of over 20GB, but encountered the same issue.
It seems unlikely that there is a lack of specifications in the execution environment.
Could the issue possibly be due to a bug in the command?
From: Abel Pau <a.pau at creaf.uab.cat<mailto:a.pau at creaf.uab.cat>>
Sent: Monday, March 4, 2024 4:57 PM
To: 寛座 智大 <tomohiro.kanza.306 at baycurrent.co.jp<mailto:tomohiro.kanza.306 at baycurrent.co.jp>>
I did similar tests with a driver I am implementing and I obtained exact the same behavior as yours.
After a few speculations I deduced that my driver was asking for too much memory for the docker capacity.
So, perhaps, Shape or Geojson asks for too much memory for the docker capacity.
I don’t know if it’s possible to make it bigger.
Abel.
De: gdal-dev <gdal-dev-bounces at lists.osgeo.org<mailto:gdal-dev-bounces at lists.osgeo.org>> En nombre de ?? ?? via gdal-dev
Enviado el: dilluns, 4 de març de 2024 3:30
Para: gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Asunto: [gdal-dev] Segmentation fault (core dumped) occurs when running ogr2ogr command on container
I am implementing batch processing to convert Shape files, publicly available as open data,
into Geojson format within a container environment.
I installed gdal-bin on top of ubuntu:22.04 base image.
The Dockerfile I implemented is as follows:
FROM ubuntu:22.04
ENV DEBIAN_FRONTEND=noninteractive
RUN apt update
RUN apt -y install apt-transport-https jq unzip openjdk-17-jdk-headless curl
# Install gdal-bin
# Reference: https://mothergeo-py.readthedocs.io/en/latest/development/how-to/gdal-ubuntu-pkg.html#how-to-install-gdal-ogr-packages-on-ubuntu
RUN apt -y install software-properties-common
RUN add-apt-repository -y ppa:ubuntugis/ppa
RUN apt update
RUN apt -y install gdal-bin
COPY ./convert.sh /convert.sh
CMD ["bash","convert.sh"]
When executing the ogr2ogr command within convert.sh, the following error occurs:
Shape: DBF Codepage = SJIS for /d1.shp
Shape: Treating as encoding 'MS932'.
GDAL: GDALOpen(/d1.shp, this=0x55f1edd77f30) succeeds as ESRI Shapefile.
GDAL: QuietDelete(/d1_raw.geojson) invoking Delete()
GDAL: GDALDriver::Create(GeoJSON,/d1_raw.geojson,0,0,0,Unknown,(nil))
GDALVectorTranslate: 5315 features written in layer 'd1'
Shape: 5315 features read on layer 'd1'.
GDAL: GDALClose(/d1.shp, this=0x55f1edd77f30)
GDAL: GDALClose(/d1_raw.geojson, this=0x55f1edd75fd0)
GDAL: In GDALDestroy - unloading GDAL shared library.
I checked if convert.sh execution is possible on the VM (host OS running Docker).
The error seems to occur only when executed within the container.
How should I resolve this?
※Environment
Host OS: ubuntu 22.04
Docker Deamon: 25.0.3
gdal-bin: 3.6.4
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240312/35c5adf4/attachment-0001.htm>
