[gdal-dev] Creating NetCDF dataset with sub datasets
Pierre Chatelier pierre at chachatelier.fr
Tue Mar 12 04:51:47 PDT 2024
Ok, I can confirm that
-creating a dataset with <n> bands with the netCDF driver works
-saving the dataset will write the expected "SUBDATASETS" domain with
"SUBDATASET_<i>_NAME=NETCDF:"<file>":"<band name>"
But I can't figure out how to customize the <band name>, which is Band1,
Band2, Band3...
I tried GDALRasterBand::SetDescription(), but without success
Also, is there a reason why AddBand() is not supported by the netCDF
driver ? I expected it to be able to add bands on demand as new "netcdf
variables".
Pierre
> Hi,
> If your input dataset has multiple bands, each band will be written as
> a separate netCDF variable, and thus read as multiple subdatasets. The
> constraint is that as your input is a single raster, all bands must
> share the same georeferencing.
> If you want to write multiple independent variables, then you'll have
> to use the GDAL multidimensional API. Cf
> https://github.com/OSGeo/gdal/blob/master/autotest/gdrivers/netcdf_multidim.py
> . h5py is also quite convenient
> Even
> Le 07/03/2024 à 09:47, Pierre Chatelier via gdal-dev a écrit :
>> Hello,
>> I just had my first encounter with a NetCDF file. GDAL opens that
>> flawlessly, I can identify the subdatasets and open/read them thanks
>> to the SUBDATASET_n_NAME, as advertised in
>> https://gdal.org/drivers/raster/netcdf.html
>> However, I am confused by the ability to create such a file with GDAL.
>> Let's say I have a bunch of images that I want to pack as NetCDF
>> through GDAL.
>> Should I use bands or groups to let GDAL create the sub datasets ?
>> Will GDAL create the metadata SUBDATASETS domain for me ?
>> The NetCDF file I am supposed to create should use HDF for sub
>> datasets. No problem for reading (I have compiled GDAL with the HDF
>> support and it works, I can open my sample file), but how do I tell
>> GDAL to *write* that ? Should I create real datasets with the GDAL
>> HDF driver and then gather them into a single one with GDAL NetCDF
>> driver ?
>> Can you give some hints about what I am supposed to do ?
>> Pierre
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
