[gdal-dev] Creating NetCDF dataset with sub datasets
Pierre Chatelier pierre at chachatelier.fr
Tue Mar 12 13:09:12 PDT 2024
My investigation, might be an issue for the github :
band->SetMetadataItem("NETCDF_VARNAME", "foo"); will generate a netCDF band name of "foo1" because there must be a non-null papszExtraDimNames for some reason (netcdfdatasetp.cpp:9630)
However
-in order for "papszExtraDimNames" to be non-null, there must be a dataset->SetMetadataItem("NETCDF_DIM_EXTRA", ...)
-NETCDF_DIM_EXTRA="{}" is an empty array tokenized as null and does not help
-NETCDF_DIM_EXTRA="{dim1_name, dim2_name, ...}" will require NETCDF_DIM_dim<i>_name_DEF={dimension_size<i>,netcdf_data_type}...
-however, using extram dims  requires that the nDimSizeTot=product_i(dimension_size<i>, ...) == nBands ( (netcdfdatasetp.cpp:9473)
-this condition is a non sense in my scenario of a fixed number of 2D bands, there is no dimension_size<i> so that product_i(dimension_size<i>, ...) == nBands
Is there a bug or an artificial limitation by the current netCDF driver implementation ?
Pierre
> On 12 Mar 2024, at 14:16, Pierre Chatelier via gdal-dev <gdal-dev at lists.osgeo.org> wrote:
> Le 12/03/2024 à 13:48, Even Rouault a écrit :
>> Le 12/03/2024 à 13:33, Pierre Chatelier a écrit :
>>>>> But I can't figure out how to customize the <band name>, which is Band1, Band2, Band3...
>>>>> I tried GDALRasterBand::SetDescription(), but without success
>>>> Looking at netcdfdataset.cpp line 9625, the netCDF variable name for a band is extracted from the NETCDF_VARNAME band metadata item of the source band.
>>> Sounds good, doesn't work.
>> It must be set on the *source* band, before creating CreateCopy(). I've just tested it successfully with:
> For now I still have two problems :
> -it means I cannot work in-place in the final netCDF dataset, I have to use another dataset and use CreateCopy()
> -for now  band->SetMetadataItem("NETCDF_VARNAME", "foo"); will generate a netCDF band name of "foo1" because there is something related to NETCDF_DIM_EXTRA that adds an index. (netcdfdatasetp.cpp:10507)
>  I am investigating if I can force (even an empty) NETCDF_DIM_EXTRA. (but for now it does not work)
>> $ gdal_translate byte.tif input.vrt
>> $ python -c "from osgeo import gdal; ds = gdal.Open('input.vrt', gdal.GA_Update); ds.GetRasterBand(1).SetMetadataItem('NETCDF_VARNAME', 'my_varname'); ds.SetMetadataItem('my_varname#long_name', 'my long name')"
>> $ gdal_translate input.vrt tmp.nc
>> $ ncdump -h tmp.nc | grep my_varname
>>     byte my_varname(y, x) ;
>>         my_varname:long_name = "my long name" ;
>>         my_varname:_Unsigned = "true" ;
>>         my_varname:valid_range = 0s, 255s ;
>>         my_varname:grid_mapping = "transverse_mercator" ;
>> Not super intuitive admitedly. This is mostly done in a way that netCDF -> netCDF CreateCopy() preserve the variable name and long_name attributes
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
