[gdal-dev] There's something strange about two tests that are very similar
Abel Pau a.pau at creaf.uab.cat
Thu Mar 14 01:51:24 PDT 2024
Sorry,
I merged from my phone and I think I did it wrong.
At this time actions are going well except the same that didn’t work at the beginning of this message. The MacOS one.
Merge remote-tracking branch 'upstream/master' into MiraMon-Vector-dr… · AbelPau/gdal at fa6f9e0 (github.com)<https://github.com/AbelPau/gdal/actions/runs/8277097153/job/22646788426#step:6:2463>
Your proposal of rebasing didn’t solved the problem in macOS.
So, I’ll try to get an image of a mac and compile, but when I tried to use a Virtual Box it was extremly slow.
Thanks for any input to try to get some call stack with the error described below.
Using gdb I obtain
ogr/ogr_basic_test.py ✓        100% ██████████
Results (7.72s):
       1 passed
[Inferior 1 (process 15792) exited normally]
And the same with Valgrind.
Thanks!
______________________________ test_ogr_basic_10 _______________________________
2464<https://github.com/AbelPau/gdal/actions/runs/8277097153/job/22646788426#step:6:2465>42:
2465<https://github.com/AbelPau/gdal/actions/runs/8277097153/job/22646788426#step:6:2466>42: def test_ogr_basic_10():
2466<https://github.com/AbelPau/gdal/actions/runs/8277097153/job/22646788426#step:6:2467>42:
2467<https://github.com/AbelPau/gdal/actions/runs/8277097153/job/22646788426#step:6:2468>42: import test_cli_utilities
2468<https://github.com/AbelPau/gdal/actions/runs/8277097153/job/22646788426#step:6:2469>42:
2469<https://github.com/AbelPau/gdal/actions/runs/8277097153/job/22646788426#step:6:2470>42: if test_cli_utilities.get_test_ogrsf_path() is None:
2470<https://github.com/AbelPau/gdal/actions/runs/8277097153/job/22646788426#step:6:2471>42: pytest.skip()
2471<https://github.com/AbelPau/gdal/actions/runs/8277097153/job/22646788426#step:6:2472>42:
2472<https://github.com/AbelPau/gdal/actions/runs/8277097153/job/22646788426#step:6:2473>42: ret = gdaltest.runexternal(
2473<https://github.com/AbelPau/gdal/actions/runs/8277097153/job/22646788426#step:6:2474>42: test_cli_utilities.get_test_ogrsf_path() + " -all_drivers"
2474<https://github.com/AbelPau/gdal/actions/runs/8277097153/job/22646788426#step:6:2475>42: )
2475<https://github.com/AbelPau/gdal/actions/runs/8277097153/job/22646788426#step:6:2476>42:
2476<https://github.com/AbelPau/gdal/actions/runs/8277097153/job/22646788426#step:6:2477>42: > assert "INFO" in ret
2477<https://github.com/AbelPau/gdal/actions/runs/8277097153/job/22646788426#step:6:2478>42: E AssertionError: assert 'INFO' in '\nERROR ret code = -4'
2478<https://github.com/AbelPau/gdal/actions/runs/8277097153/job/22646788426#step:6:2479>42:
2479<https://github.com/AbelPau/gdal/actions/runs/8277097153/job/22646788426#step:6:2480>42: /Users/runner/work/gdal/gdal/build/autotest/ogr/ogr_basic_test.py:454: AssertionError
De: gdal-dev <gdal-dev-bounces at lists.osgeo.org> En nombre de Abel Pau via gdal-dev
Enviado el: dijous, 14 de març de 2024 7:44
Para: Even Rouault <even.rouault at spatialys.com>; gdal-dev at lists.osgeo.org
Asunto: Re: [gdal-dev] There's something strange about two tests that are very similar
I rebased yesterday, after your message, but same error appeared and some more.
I rebased al 7.00 again and it seems that there are again some errors in linux builds.
I assume it's because of lasts code updates. I'll wait until something stable to rebase again.
Enviat des de l'Outlook per a l'Android<https://aka.ms/AAb9ysg>
From: Even Rouault <even.rouault at spatialys.com<mailto:even.rouault at spatialys.com>>
Sent: Thursday, March 14, 2024 12:15:38 AM
To: Abel Pau <a.pau at creaf.uab.cat<mailto:a.pau at creaf.uab.cat>>; gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org> <gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>>
Subject: Re: [gdal-dev] There's something strange about two tests that are very similar
try rebasing on top of latest master. It looks like the errors are only those fixed per https://github.com/OSGeo/gdal/commit/6703d3071de7155d320a39a580f27230428dcaca
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240314/d5588f8d/attachment-0001.htm>
