[gdal-dev] FW: [External] : GDAL 3.8.4 build on windows failed at linking
Even Rouault even.rouault at spatialys.com
Thu Mar 14 08:52:16 PDT 2024
possibly already fixed in master with commit
https://github.com/OSGeo/gdal/commit/849226ce1a9
Even
Le 14/03/2024 à 16:47, Fengting Chen a écrit :
> After upgrading the windows build environment to VS2022, I got the
> following linker error:
> vsidataio.obj : error LNK2005: "void __cdecl jpeg_vsiio_src(struct
> jpeg_decompress_struct *,struct VSIVirtualHandle *)"
> (?jpeg_vsiio_src@@YAXPEAUjpeg_decompress_struct@@PEAUVSIVirtualHandle@@@Z)
> already defined in vsidataio.obj [C:\fechen\gdal-3.8.4\build\GDAL.vcxproj]
> vsidataio.obj : error LNK2005: "void __cdecl jpeg_vsiio_dest(struct
> jpeg_compress_struct *,struct VSIVirtualHandle *)"
> (?jpeg_vsiio_dest@@YAXPEAUjpeg_compress_struct@@PEAUVSIVirtualHandle@@@Z)
> Creating library C:/fechen/gdal-3.8.4/build/Debug/gdald.lib and object
> C:/fechen/gdal-3.8.4/build/Debug/gdald.exp
> C:\fechen\gdal-3.8.4\build\Debug\gdald.dll : fatal error LNK1169: one
> or more multiply defined symbols found
> I set “GDAL_USE_JPEG_INTERNAL”  with “ON”. Any suggestions?
> Thanks!
> *From: *Even Rouault <even.rouault at spatialys.com>
> *Date: *Tuesday, March 12, 2024 at 12:56 PM
> *To: *Fengting Chen <fengting.chen at oracle.com>,
> gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
> *Subject: *Re: [gdal-dev] FW: [External] : GDAL 3.8.4 build on windows
> failed at linking
> Not the answer you'll probably want to hear, but:
> - Use an up-to-date compiler
> - Use package distributions like vcpkg or conda-forge that already
> brings all the dependencies "for free"
> - It seems you mix builds of different compilers (VS vs mingw). That's
> a bit asking for troubles ;-)
> Le 12/03/2024 à 17:48, Fengting Chen via gdal-dev a écrit :
>     Resend with more information:
>     I am trying to build GDAL 3.8.4 on windows under VS2015. The build
>     failed at linking stage that a bunch of external symbols not
>     found, specifically the symbols in libproj, libcurl. I checked the
>     dll library stub .lib for libproj and libcurl using “dumpbin” and
>     found the symbols in the library a little different, for example
>     the linker error shows “__imp__curl_slist_append” not found, the
>     symbol output from the “dumpbin” is  “__imp_curl_slist_append” .
>     Any idea how to fix this?
>     Thanks!
>     *From: *gdal-dev <gdal-dev-bounces at lists.osgeo.org>
>     <mailto:gdal-dev-bounces at lists.osgeo.org> on behalf of Fengting
>     Chen via gdal-dev <gdal-dev at lists.osgeo.org>
>     <mailto:gdal-dev at lists.osgeo.org>
>     *Date: *Monday, March 11, 2024 at 4:50 PM
>     *To: *gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
>     *Subject: *[External] : [gdal-dev] GDAL 3.8.4 build on windows
>     failed at linking
>     GDAL 3.8.4 build on Windows from VS2015 x64 command prompt: “cmake
>     –build .” throws the following error (there are more similar errors):
>     cpl_vsil_az.obj : error LNK2001: unresolved external symbol
>     __imp__curl_slist_append [E:\gdal-3.8.4\build\GDAL.vcxproj]
>     cmake options has:
>     set (GDAL_USE_CURL                ON   CACHE  BOOL "" FORCE)
>     set (CURL_INCLUDE_DIR "E:/SDK/curl-8.6.0_1-win64-mingw/include"
>     CACHE PATH "" FORCE)
>     set (CURL_LIBRARY_RELEASE
>     "E:/SDK/curl-8.6.0_1-win64-mingw/bin/libcurl-x64.lib" CACHE
>     FILEPATH "" FORCE)
>     libcurl-x64.lib is the DLL stub. Using dumpbin on libcurl-x64.lib
>     shows that “__imp_curl_slist_append” is available. But the linker
>     error is “__imp__curl_slist_append” not found. There is an extra
>     “_” in it.
>     Any idea why this error occurred?
>     Thanks!
>     _______________________________________________
>     gdal-dev mailing list
>     https://lists.osgeo.org/mailman/listinfo/gdal-dev  <https://urldefense.com/v3/__https:/lists.osgeo.org/mailman/listinfo/gdal-dev__;!!ACWV5N9M2RV99hQ!N8ZTSFcueASfCUE2XGRgmOMaX6fq5SFf-Tq25Un9Kws27WD09uZjzbSDMeAzmhzOrmz0mgSpFItXVTdprbA3RxpGPNVk$>
> http://www.spatialys.com  <https://urldefense.com/v3/__http:/www.spatialys.com__;!!ACWV5N9M2RV99hQ!N8ZTSFcueASfCUE2XGRgmOMaX6fq5SFf-Tq25Un9Kws27WD09uZjzbSDMeAzmhzOrmz0mgSpFItXVTdprbA3R_bZl290$>
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240314/9d22bfaf/attachment.htm>
