[gdal-dev] FW: [External] : GDAL 3.8.4 build on windows failed at linking
Even Rouault even.rouault at spatialys.com
Thu Mar 14 11:42:40 PDT 2024
Le 14/03/2024 à 19:27, Fengting Chen a écrit :
> I included this fix but it doesn’t help. I was building the georaster
> driver as a plugin but the linker failed at building gdal library. So
> the fix doesn’t seem to be related to the problem.
You can't build the driver as a plugin with internal libjpeg. CMake
should prevent you from doing that because of
https://github.com/OSGeo/gdal/blob/master/frmts/georaster/CMakeLists.txt#L6
But I now remember (thanks git blame!) that during the defered driver
loading RFC development, I found that the condition to check that was
broken. This was fixed in
https://github.com/OSGeo/gdal/commit/adb0fd695253cf9fb91bee46309e6c66b25e8d65
> Building Custom Rule C:/fechen/gdal-3.8.4/CMakeLists.txt
> vsidataio.obj : error LNK2005: "void __cdecl jpeg_vsiio_src(struct
> jpeg_decompress_struct *,struct VSIVirtualHandle *)"
> (?jpeg_vsiio_src@@YAXPEAUjpeg_decompress_struct@@PEAUVSIVirtualHandle@@@Z)
> already defined in vsidataio.obj [C:\fechen\gdal-3.8.4\build\GDAL.vcxproj]
> vsidataio.obj : error LNK2005: "void __cdecl jpeg_vsiio_dest(struct
> jpeg_compress_struct *,struct VSIVirtualHandle *)"
> (?jpeg_vsiio_dest@@YAXPEAUjpeg_compress_struct@@PEAUVSIVirtualHandle@@@Z)
> Creating library C:/fechen/gdal-3.8.4/build/Debug/gdald.lib and object
> C:/fechen/gdal-3.8.4/build/Debug/gdald.exp
> C:\fechen\gdal-3.8.4\build\Debug\gdald.dll : fatal error LNK1169: one
> or more multiply defined symbols found
> *From: *Even Rouault <even.rouault at spatialys.com>
> *Date: *Thursday, March 14, 2024 at 11:52 AM
> *To: *Fengting Chen <fengting.chen at oracle.com>,
> gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
> *Subject: *Re: [gdal-dev] FW: [External] : GDAL 3.8.4 build on windows
> failed at linking
> Hi,
> possibly already fixed in master with commit
> https://github.com/OSGeo/gdal/commit/849226ce1a9
> <https://urldefense.com/v3/__https:/github.com/OSGeo/gdal/commit/849226ce1a9__;!!ACWV5N9M2RV99hQ!KbMOD2u6nEacIP2ix07m6Y00zYu21fPOi8h2u_p-cjBCRSh9U8hYhTmK3txq5tv2LAvFBFXNfErVwdiaD9U8YKKFUCjQ$>
> Even
> Le 14/03/2024 à 16:47, Fengting Chen a écrit :
>     After upgrading the windows build environment to VS2022, I got the
>     following linker error:
>     jpeg_vsiio_dest(struct jpeg_compress_struct *,struct
>     object C:/fechen/gdal-3.8.4/build/Debug/gdald.exp
>     one or more multiply defined symbols found
>     I set “GDAL_USE_JPEG_INTERNAL”  with “ON”. Any suggestions?
>     Thanks!
>     <mailto:even.rouault at spatialys.com>
>     *Date: *Tuesday, March 12, 2024 at 12:56 PM
>     <mailto:fengting.chen at oracle.com>, gdal-dev at lists.osgeo.org
>     <gdal-dev at lists.osgeo.org> <mailto:gdal-dev at lists.osgeo.org>
>     Not the answer you'll probably want to hear, but:
>     - Use an up-to-date compiler
>     - Use package distributions like vcpkg or conda-forge that already
>     brings all the dependencies "for free"
>     - It seems you mix builds of different compilers (VS vs mingw).
>     That's a bit asking for troubles ;-)
>     Le 12/03/2024 à 17:48, Fengting Chen via gdal-dev a écrit :
>         Resend with more information:
>         I am trying to build GDAL 3.8.4 on windows under VS2015. The
>         build failed at linking stage that a bunch of external symbols
>         not found, specifically the symbols in libproj, libcurl. I
>         checked the dll library stub .lib for libproj and libcurl
>         using “dumpbin” and found the symbols in the library a little
>         different, for example the linker error shows
>         “__imp__curl_slist_append” not found, the symbol output from
>         the “dumpbin” is  “__imp_curl_slist_append” .
>         Any idea how to fix this?
>         Thanks!
>         *From: *gdal-dev <gdal-dev-bounces at lists.osgeo.org>
>         <mailto:gdal-dev-bounces at lists.osgeo.org> on behalf of
>         Fengting Chen via gdal-dev <gdal-dev at lists.osgeo.org>
>         *Date: *Monday, March 11, 2024 at 4:50 PM
>         *To: *gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
>         *Subject: *[External] : [gdal-dev] GDAL 3.8.4 build on windows
>         failed at linking
>         GDAL 3.8.4 build on Windows from VS2015 x64 command prompt:
>         “cmake –build .” throws the following error (there are more
>         similar errors):
>         cpl_vsil_az.obj : error LNK2001: unresolved external symbol
>         __imp__curl_slist_append [E:\gdal-3.8.4\build\GDAL.vcxproj]
>         cmake options has:
>         set (GDAL_USE_CURL                ON CACHE  BOOL "" FORCE)
>         set (CURL_INCLUDE_DIR
>         "E:/SDK/curl-8.6.0_1-win64-mingw/include" CACHE PATH "" FORCE)
>         set (CURL_LIBRARY_RELEASE
>         "E:/SDK/curl-8.6.0_1-win64-mingw/bin/libcurl-x64.lib" CACHE
>         FILEPATH "" FORCE)
>         libcurl-x64.lib is the DLL stub. Using dumpbin on
>         libcurl-x64.lib shows that “__imp_curl_slist_append” is
>         available. But the linker error is “__imp__curl_slist_append”
>         not found. There is an extra “_” in it.
>         Any idea why this error occurred?
>         Thanks!
>         _______________________________________________
>         gdal-dev mailing list
>         https://lists.osgeo.org/mailman/listinfo/gdal-dev  <https://urldefense.com/v3/__https:/lists.osgeo.org/mailman/listinfo/gdal-dev__;!!ACWV5N9M2RV99hQ!N8ZTSFcueASfCUE2XGRgmOMaX6fq5SFf-Tq25Un9Kws27WD09uZjzbSDMeAzmhzOrmz0mgSpFItXVTdprbA3RxpGPNVk$>
>     http://www.spatialys.com  <https://urldefense.com/v3/__http:/www.spatialys.com__;!!ACWV5N9M2RV99hQ!N8ZTSFcueASfCUE2XGRgmOMaX6fq5SFf-Tq25Un9Kws27WD09uZjzbSDMeAzmhzOrmz0mgSpFItXVTdprbA3R_bZl290$>
>     My software is free, but my time generally not.
> http://www.spatialys.com  <https://urldefense.com/v3/__http:/www.spatialys.com__;!!ACWV5N9M2RV99hQ!KbMOD2u6nEacIP2ix07m6Y00zYu21fPOi8h2u_p-cjBCRSh9U8hYhTmK3txq5tv2LAvFBFXNfErVwdiaD9U8YKzOL5Qh$>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240314/cca3bf1f/attachment-0001.htm>
