[gdal-dev] Censor area in tiles of aerial image
Even Rouault even.rouault at spatialys.com
Tue Mar 19 06:05:44 PDT 2024
Why not just trying?
Demo:
$ gdal_create -outsize 10 10 -burn 255 test.tif -a_srs EPSG:4326 -a_ullr
0 10 10 0
$ gdal_rasterize -burn 0
'{"type":"Polygon","coordinates":[[[2,2],[2,4],[4,4],[4,2],[2,2]]]}'
test.tif
$ gdal_translate test.tif /vsistdout/ -of aaigrid
ncols        10
nrows        10
xllcorner    0.000000000000
yllcorner    0.000000000000
cellsize     1.000000000000
255 255 255 255 255 255 255 255 255 255
255 255 0 0 255 255 255 255 255 255
That said, I've attempted to clarifiy it pe
https://github.com/OSGeo/gdal/commit/4377ce22ec8d26b76760e8c1e4a9ffa2bd240b7d
Le 19/03/2024 à 13:42, Carsten Lockenkötter via gdal-dev a écrit :
> Hi Frank,
> I have read about gdal_rasterize but it seems it works a bit different
> as i need it.
> Gdal_rasterize converts a vector layer to a raster layer with specific
> dimensions and create a new file, like a mask.
> It could be work for me yes, because i publish the raster files as
> image mosiac at the geoserver.
> Maybe the new "mask" file overlays on me original files and the
> created wmts tiles of the geoserver could contain the mask.
> I will try it, but is there another option to burn the vectorlayer
> into existing tiles?
> Regards,
> Carsten
> Am 19.03.24, 00:14 schrieb Frank Warmerdam <warmerdam at pobox.com>:
>     Carsten,
>     The gdal_rasterize command allows you to "burn in" polygons from
>     an OGR supported datasource into an existing raster.  If your
>     raster is a 3 band RGB file, you could use --burn 100 150 200 to
>     burn in the RGB value (100,150,200).   This will only work if the
>     raster format you are using supports update-in-place.
>     You would have to regenerate pyramids after this process -- they
>     are not automatically updated by GDAL when the "base layer" is
>     updated.
>     Best regards,
>     Frank
>     On Mon, Mar 18, 2024 at 5:34 PM Carsten Lockenkötter via gdal-dev
>     <gdal-dev at lists.osgeo.org> wrote:
>         Hi,
>         is it possible to censor specific areas of an aerial image
>         using GDAL?
>         I have several smaller tiles that I've already transformed
>         into my desired coordinate system and generated internal pyramids.
>         Subsequently, I would like to censor certain areas based on
>         polygons (e.g., from a shapefile or an Oracle DB) (coloring
>         them grayish).
>         Set the color must be done after transforming coordinatesystem
>         and generating pyramids.
>         I usually use the compiled Windows binaries from
>         gisinternals.com <http://gisinternals.com>.
>         Presumably, my plan doesn't work with that, right? At least I
>         haven't found anything in that direction.
>         I suppose this could be done with a Python, but I've never
>         worked with Python before.
>         Do I need to adjust the internal pyramids as well? Or do I
>         have to recreate them?
>         Could you please show me a brief example of how it could work,
>         so I have an approach?
>         I just need an idea of how to implement this and possibly some
>         tips on what else I need to consider.
>         Regards,
>         Carsten
>         _______________________________________________
>         gdal-dev mailing list
>         https://lists.osgeo.org/mailman/listinfo/gdal-dev
>     I set the clouds in motion - turn up   | Frank Warmerdam,
>     light and sound - activate the windows | USA: +1 650-701-7823
>     and watch the world go round - Rush    | CAN: +1 343-550-9984
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240319/1d6d3500/attachment-0001.htm>
