[gdal-dev] Python binding installation on windows
Even Rouault even.rouault at spatialys.com
Tue Mar 19 12:22:04 PDT 2024
Le 19/03/2024 à 20:14, Fengting Chen via gdal-dev a écrit :
> Hi, I was able to build the GDAL with python binding on without error
> on windows. However, “cmake --build . --target  install --config
> Release” command doesn’t install the python site-packages etc to the
> specified “CMAKE_INSTALL_PREFIX” directory. The rest of the GDAL
> components were installed properly.  Did I miss anything?
What I can tell is that .github/workflows/cmake_builds.yml lines 480
"cmake --build $GITHUB_WORKSPACE/build --config Release --target
install" seems to do the job on CI :
https://github.com/OSGeo/gdal/actions/runs/8346148650/job/22842755713
copying build\lib.win-amd64-cpython-310\osgeo\gdal.py ->
D:\\a\\gdal\\gdal\\install-gdal\Lib\site-packages\osgeo
copying build\lib.win-amd64-cpython-310\osgeo\gdalconst.py ->
copying build\lib.win-amd64-cpython-310\osgeo\gdalnumeric.py ->
copying build\lib.win-amd64-cpython-310\osgeo\gdal_array.py ->
copying build\lib.win-amd64-cpython-310\osgeo\gnm.py ->
copying build\lib.win-amd64-cpython-310\osgeo\ogr.py ->
copying build\lib.win-amd64-cpython-310\osgeo\osr.py ->
copying build\lib.win-amd64-cpython-310\osgeo\_gdal.cp310-win_amd64.pyd
-> D:\\a\\gdal\\gdal\\install-gdal\Lib\site-packages\osgeo
copying
build\lib.win-amd64-cpython-310\osgeo\_gdalconst.cp310-win_amd64.pyd ->
copying
build\lib.win-amd64-cpython-310\osgeo\_gdal_array.cp310-win_amd64.pyd ->
copying build\lib.win-amd64-cpython-310\osgeo\_gnm.cp310-win_amd64.pyd
copying build\lib.win-amd64-cpython-310\osgeo\_ogr.cp310-win_amd64.pyd
copying build\lib.win-amd64-cpython-310\osgeo\_osr.cp310-win_amd64.pyd
which setuptools version do you use? which logs do you get?
Perhaps also try running "python setup.py install" manually from the
swig/python build directory
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240319/cd1e977a/attachment.htm>
