[gdal-dev] Compiling Poppler plugin under Windows (missing dependencies with GisInterrnals)
Philippe Ghesquiere philippe.ghesquiere at airbus.com
Thu Mar 21 10:49:31 PDT 2024
Thanks Even.
As far as Gisinternals is concerned, I think they are still using "nmake"
to compile the PDF plugin (see makefile
<https://github.com/gisinternals/buildsystem/blob/main/Makefile>).
This may explain why they don't need the POPPLER_EXTRA_LIBRARIES parameter.
Concerning the document, I need to check how to do it from my office
(firewall strict rules ...)
Philippe
On Thu, Mar 21, 2024 at 2:07 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Philippe,
> I guess, I did not initialize POPPLER_EXTRA_LIBRARIES:
>    - is its type STRING ?
> Yes
>    - what separator should I use between library name ?
> Semicolon ';'
> I see this was added per https://github.com/OSGeo/gdal/commit/95ee1f855cd
> and
> https://github.com/OSGeo/gdal/commit/d69257df35c8ae3c283dce2077b7c49720f99663
> , although I'm a bit puzzled why gisinternals build recipe itself doesn't
> need it.
> Feel free to submit a pull request to
> https://gdal.org/development/building_from_source.html to document that
> variable
> Even
> -- http://www.spatialys.com
> My software is free, but my time generally not.
The information in this e-mail is confidential. The contents may not be disclosed or used by anyone other than the addressee. Access to this e-mail by anyone else is unauthorised.
If you are not the intended recipient, please notify Airbus immediately and delete this e-mail.
Airbus cannot accept any responsibility for the accuracy or completeness of this e-mail as it has been sent over public networks. If you have any concerns over the content of this message or its Accuracy or Integrity, please contact Airbus immediately.
All outgoing e-mails from Airbus are checked using regularly updated virus scanning software but you should take whatever measures you deem to be appropriate to ensure that this message and any attachments are virus free.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240321/06cfb56b/attachment.htm>
