[gdal-dev] USGS 3DEP (3D Elevation Program) - feet should be metres, how can I fix this?
Even Rouault even.rouault at spatialys.com
Fri Mar 22 01:57:00 PDT 2024
having looked at the file, I believe GDAL behaves correctly given the
metadata in the file. This is clearly a unit type attached to the Band,
and it should be corrected by the data producer to reflect what is
really used in it
One way to correct it on your side is for example this little Python snippet
from osgeo import gdal
ds = gdal.Open('test.tif')
ds.GetRasterBand(1).SetUnitType('metre')
As the file is used in read-only mode, this will generate an auxiliary
.aux.xml side car file overriding the unit.
You can also directly override the wrong metadata inside the TIFF with
ds = gdal.OpenEx('test.tif', open_options=['IGNORE_COG_LAYOUT_BREAK=YES'])
The IGNORE_COG_LAYOUT_BREAK=YES open option is because modifying TIFF
metadata causes it to be rewritten at the end of the file, which
"breaks" the COG convention. But that's still a perfectly valid GeoTIFF
file, and will not change anything for local use of such file. You could
reprocess that to a fully compliant COG with gdal_translate -of COG
Regarding how that is used by gdalwarp, the doc enhancement at
https://github.com/OSGeo/gdal/pull/9527 captures my initial attempt at
answering your questions.
Even
Le 22/03/2024 à 01:16, Conrad Bielski a écrit :
> Just realised I should have put you also in CC
> Here is my response message again.
> Thanks Even,
> you are correct about the tag number (I sent the incorrrect one).
> I have provided a sample tif and some other descriptions of the issue
> here:
> bad_geotiff - Google Drive
> <https://drive.google.com/drive/folders/1LVJqoKrnLRf6_5FpE7a5SrUGIWBPQmqa?usp=sharing>
> The three files there are the following:
> 1.  A bad tiff (this is slightly smaller; they are all pretty big).
> 2.  A GDAL info dump (survey feet is almost at the bottom)
> 3. A PDF with an explanation of the issue
> thanks for your help.
> Conrad
> On Thursday, March 21, 2024 at 04:49:57 PM EDT, Even Rouault
> <even.rouault at spatialys.com> wrote:
> Le 21/03/2024 à 21:45, Conrad Bielski via gdal-dev a écrit :
> Hello GDALers,
> I have a question about reading USGS 3DEP (3D Elevation Program) data.
> Inside of this data, a GEOTIFF tag 42114 is provided which is causing
> problems with datum shifts.
> There's no such thing as a GEOTIFF tag 42114.
> The closest tags are:
> #define TIFFTAG_GDAL_METADATA 42112
> #define TIFFTAG_GDAL_NODATA 42113
> It would be helpuful if you could provide the file, or the result of a
> "tiffdump -m 1000 the.tif" and "listgeo the.tif" on it.
> And was the .tif.aux.xml provided with the TIFF, or computed by GDAL.
> Because the information might come from it too.
>> So when I use GDAL to compute the datum shifts, the tag is read and
>> interprets that the DEM is showing elevation in 'feet' while the DEM
>> is actually in metres. The DEMs are in fact in meter elevations and
>> meter UTM horizontal coordinates. This is obviously erroneously
>> integrated into the tag.
>> So my question is whether anyone has come across this issue and found
>> a solution? Is there a way to edit the offending tag so that it is
>> correctly interpreted as metres instead of feet? Other potential
>> solutions so that GDAL interprets the elevation correctly?
>> Thanks in advance for your help. I provide below the output of
>> gdalinfo which I hope could help with the offending info in bold.
>> Have a great day,
>> Conrad
>> Driver: GTiff/GeoTIFF
>> Files:
>> I:\v3_us_3dep\asheville\ashevilleUSGS_1M_17_x34y392_NC_Phase5_2018_A18.tif
>>  I:\v3_us_3dep\asheville\ashevilleUSGS_1M_17_x34y392_NC_Phase5_2018_A18.tif.aux.xml
>> Size is 10012, 10012
>> Coordinate System is:
>> PROJCRS["NAD83 / UTM zone 17N",
>>     BASEGEOGCRS["NAD83",
>>         DATUM["North American Datum 1983",
>>             ELLIPSOID["GRS 1980",6378137,298.257222101,
>>                 LENGTHUNIT["metre",1]]],
>>         PRIMEM["Greenwich",0,
>> ANGLEUNIT["degree",0.0174532925199433]],
>>         ID["EPSG",4269]],
>>     CONVERSION["UTM zone 17N",
>>         METHOD["Transverse Mercator",
>>             ID["EPSG",9807]],
>>         PARAMETER["Latitude of natural origin",0,
>> ANGLEUNIT["degree",0.0174532925199433],
>>             ID["EPSG",8801]],
>>         PARAMETER["Longitude of natural origin",-81,
>>             ID["EPSG",8802]],
>>         PARAMETER["Scale factor at natural origin",0.9996,
>>             SCALEUNIT["unity",1],
>>             ID["EPSG",8805]],
>>         PARAMETER["False easting",500000,
>>             LENGTHUNIT["metre",1],
>>             ID["EPSG",8806]],
>>         PARAMETER["False northing",0,
>>             ID["EPSG",8807]]],
>>     CS[Cartesian,2],
>>         AXIS["(E)",east,
>>             ORDER[1],
>>             LENGTHUNIT["metre",1]],
>>         AXIS["(N)",north,
>>             ORDER[2],
>>     USAGE[
>>         SCOPE["Engineering survey, topographic mapping."],
>>         AREA["North America - between 84°W and 78°W - onshore and
>> offshore. Canada - Nunavut; Ontario; Quebec. United States (USA) -
>> Florida; Georgia; Kentucky; Maryland; Michigan; New York; North
>> Carolina; Ohio; Pennsylvania; South Carolina; Tennessee; Virginia;
>> West Virginia."],
>>         BBOX[23.81,-84,84,-78]],
>>     ID["EPSG",26917]]
>> Data axis to CRS axis mapping: 1,2
>> Origin = (339993.999958705157042,3920005.999981591943651)
>> Pixel Size = (1.000000000000000,-1.000000000000000)
>> Metadata:
>>   AREA_OR_POINT=Area
>> Image Structure Metadata:
>>   COMPRESSION=LZW
>>   INTERLEAVE=BAND
>>   LAYOUT=COG
>>   PREDICTOR=3
>> Corner Coordinates:
>> Upper Left  (  339994.000, 3920006.000) ( 82d45'43.98"W, 35d24'38.21"N)
>> Lower Left  (  339994.000, 3909994.000) ( 82d45'36.92"W, 35d19'13.36"N)
>> Upper Right (  350006.000, 3920006.000) ( 82d39' 7.17"W, 35d24'43.82"N)
>> Lower Right (  350006.000, 3909994.000) ( 82d39' 0.55"W, 35d19'18.95"N)
>> Center      (  345000.000, 3915000.000) ( 82d42'22.15"W, 35d21'58.63"N)
>> Band 1 Block=512x512 Type=Float32, ColorInterp=Gray
>>   Min=669.509 Max=1604.949
>>   Minimum=669.509, Maximum=1604.949, Mean=988.295, StdDev=159.804
>>   NoData Value=-999999
>>   Overviews: 5006x5006, 2503x2503, 1251x1251, 625x625, 312x312
>> *Unit Type: US survey foot*
>>   Metadata:
>>     STATISTICS_APPROXIMATE=YES
>>     STATISTICS_MAXIMUM=1604.9490966797
>>     STATISTICS_MEAN=988.29463693706
>>     STATISTICS_MINIMUM=669.50915527344
>>     STATISTICS_STDDEV=159.80361228109
>>     STATISTICS_VALID_PERCENT=100
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org  <mailto:gdal-dev at lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev  <https://lists.osgeo.org/mailman/listinfo/gdal-dev>
> http://www.spatialys.com  <http://www.spatialys.com>
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240322/b2fe6da0/attachment-0001.htm>
