[gdal-dev] Issue with using GDAL warp
Ian Hannah Ian.Hannah at metasphere.co.uk
Sun Mar 24 11:51:18 PDT 2024
I am using 3.8.4  of GDAL .NET and running this code:
                    string[] warpOptions =
                        "outputType", GdalConst.GDT_Byte.ToString(),
                        "srcSRS", projectionWKT,
                        "dstSRS", "EPSG:3857",
                        "accessMode", "overwrite"
                    string geoTiffOutputFileName = Path.GetTempFileName();
                    string pngOutputFileName = convertToImage ? Path.GetTempFileName() : null;
                    try
                        GDALVectorTranslateOptions gdalWarpOptions = new GDALVectorTranslateOptions(warpOptions);
                        using (Dataset outputDataset = Gdal.wrapper_GDALVectorTranslateDestName(geoTiffOutputFileName, dataset, gdalWarpOptions, null, null))
                            if (convertToImage)
                                string[] translateOptions = { "-of", "PNG" };
                                using (Gdal.wrapper_GDALTranslate(pngOutputFileName, outputDataset, new GDALTranslateOptions(translateOptions), null, null)) { }
And on the call to Gdal.wrapper_GDALVectorTranslateDestName I get the following error:
System.ApplicationException: 'Cannot guess driver for F:\Temp\2\tmp7A67.tmp'
This is in the generation of the geoTiffOutputFileName file.
Does anyone know why I am getting this error?
Thanks
Ian
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240324/721b86ac/attachment.htm>
