[gdal-dev] [EXTERNAL] Re: gdal-dev Digest, Vol 238, Issue 82
Newcomb, Doug doug_newcomb at fws.gov
Mon Mar 25 06:39:07 PDT 2024
FYI,
If you find errors in the 3DEP data, send an email to tnm_help at usgs.gov .  I have forwarded your email with the list of files to that address.
Doug
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Conrad Bielski via gdal-dev <gdal-dev at lists.osgeo.org>
Sent: Thursday, March 21, 2024 8:15 PM
To: gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Subject: [EXTERNAL] Re: [gdal-dev] gdal-dev Digest, Vol 238, Issue 82
 This email has been received from outside of DOI - Use caution before clicking on links, opening attachments, or responding.
Thanks Even,
you are correct about the tag number (I sent the incorrrect one).
I have provided a sample tif and some other descriptions of the issue here:
bad_geotiff - Google Drive<https://drive.google.com/drive/folders/1LVJqoKrnLRf6_5FpE7a5SrUGIWBPQmqa?usp=sharing>
[https://s.yimg.com/lb/brands/80x80_google.png]
The three files there are the following:
1.  A bad tiff (this is slightly smaller; they are all pretty big).
2.  A GDAL info dump (survey feet is almost at the bottom)
3. A PDF with an explanation of the issue
thanks for your help.
Conrad
On Thursday, March 21, 2024 at 04:50:19 PM EDT, gdal-dev-request at lists.osgeo.org <gdal-dev-request at lists.osgeo.org> wrote:
Send gdal-dev mailing list submissions to
    gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
To subscribe or unsubscribe via the World Wide Web, visit
    https://lists.osgeo.org/mailman/listinfo/gdal-dev
or, via email, send a message with subject or body 'help' to
    gdal-dev-request at lists.osgeo.org<mailto:gdal-dev-request at lists.osgeo.org>
You can reach the person managing the list at
    gdal-dev-owner at lists.osgeo.org<mailto:gdal-dev-owner at lists.osgeo.org>
When replying, please edit your Subject line so it is more specific
than "Re: Contents of gdal-dev digest..."
Today's Topics:
  1. USGS 3DEP (3D Elevation Program) - feet should be metres, how
      can I fix this? (Conrad Bielski)
  2. Re: USGS 3DEP (3D Elevation Program) - feet should be metres,
      how can I fix this? (Even Rouault)
Message: 1
Date: Thu, 21 Mar 2024 20:45:27 +0000 (UTC)
From: Conrad Bielski <conrad_bielski at yahoo.com<mailto:conrad_bielski at yahoo.com>>
To: "gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>>
Subject: [gdal-dev] USGS 3DEP (3D Elevation Program) - feet should be
    metres, how can I fix this?
Message-ID: <1045195440.383478.1711053927068 at mail.yahoo.com<mailto:1045195440.383478.1711053927068 at mail.yahoo.com>>
Content-Type: text/plain; charset="utf-8"
Hello GDALers,
I have a question about reading USGS 3DEP (3D Elevation Program) data. Inside of this data, a GEOTIFF tag 42114 is provided which is causing problems with datum shifts.
So when I use GDAL to compute the datum shifts, the tag is read and interprets that the DEM is showing elevation in 'feet' while the DEM is actually in metres. The DEMs are in fact in meter elevations and meter UTM horizontal coordinates. This is obviously erroneously integrated into the tag.
So my question is whether anyone has come across this issue and found a solution? Is there a way to edit the offending tag so that it is correctly interpreted as metres instead of feet? Other potential solutions so that GDAL interprets the elevation correctly?
Thanks in advance for your help. I provide below the output of gdalinfo which I hope could help with the offending info in bold.
Have a great day,
Conrad
Driver: GTiff/GeoTIFF
Files: I:\v3_us_3dep\asheville\ashevilleUSGS_1M_17_x34y392_NC_Phase5_2018_A18.tif
? ? ? ?I:\v3_us_3dep\asheville\ashevilleUSGS_1M_17_x34y392_NC_Phase5_2018_A18.tif.aux.xml
Size is 10012, 10012
Coordinate System is:
PROJCRS["NAD83 / UTM zone 17N",
? ? BASEGEOGCRS["NAD83",
? ? ? ? DATUM["North American Datum 1983",
? ? ? ? ? ? ELLIPSOID["GRS 1980",6378137,298.257222101,
? ? ? ? ? ? ? ? LENGTHUNIT["metre",1]]],
? ? ? ? PRIMEM["Greenwich",0,
? ? ? ? ? ? ANGLEUNIT["degree",0.0174532925199433]],
? ? ? ? ID["EPSG",4269]],
? ? CONVERSION["UTM zone 17N",
? ? ? ? METHOD["Transverse Mercator",
? ? ? ? ? ? ID["EPSG",9807]],
? ? ? ? PARAMETER["Latitude of natural origin",0,
? ? ? ? ? ? ANGLEUNIT["degree",0.0174532925199433],
? ? ? ? ? ? ID["EPSG",8801]],
? ? ? ? PARAMETER["Longitude of natural origin",-81,
? ? ? ? ? ? ID["EPSG",8802]],
? ? ? ? PARAMETER["Scale factor at natural origin",0.9996,
? ? ? ? ? ? SCALEUNIT["unity",1],
? ? ? ? ? ? ID["EPSG",8805]],
? ? ? ? PARAMETER["False easting",500000,
? ? ? ? ? ? LENGTHUNIT["metre",1],
? ? ? ? ? ? ID["EPSG",8806]],
? ? ? ? PARAMETER["False northing",0,
? ? ? ? ? ? ID["EPSG",8807]]],
? ? CS[Cartesian,2],
? ? ? ? AXIS["(E)",east,
? ? ? ? ? ? ORDER[1],
? ? ? ? ? ? LENGTHUNIT["metre",1]],
? ? ? ? AXIS["(N)",north,
? ? ? ? ? ? ORDER[2],
? ? USAGE[
? ? ? ? SCOPE["Engineering survey, topographic mapping."],
? ? ? ? AREA["North America - between 84?W and 78?W - onshore and offshore. Canada - Nunavut; Ontario; Quebec. United States (USA) - Florida; Georgia; Kentucky; Maryland; Michigan; New York; North Carolina; Ohio; Pennsylvania; South Carolina; Tennessee; Virginia; West Virginia."],
? ? ? ? BBOX[23.81,-84,84,-78]],
? ? ID["EPSG",26917]]
Data axis to CRS axis mapping: 1,2
Origin = (339993.999958705157042,3920005.999981591943651)
Pixel Size = (1.000000000000000,-1.000000000000000)
Metadata:
? AREA_OR_POINT=Area
Image Structure Metadata:
? COMPRESSION=LZW
? INTERLEAVE=BAND
? LAYOUT=COG
? PREDICTOR=3
Corner Coordinates:
Upper Left ?( ?339994.000, 3920006.000) ( 82d45'43.98"W, 35d24'38.21"N)
Lower Left ?( ?339994.000, 3909994.000) ( 82d45'36.92"W, 35d19'13.36"N)
Upper Right ( ?350006.000, 3920006.000) ( 82d39' 7.17"W, 35d24'43.82"N)
Lower Right ( ?350006.000, 3909994.000) ( 82d39' 0.55"W, 35d19'18.95"N)
Center ? ? ?( ?345000.000, 3915000.000) ( 82d42'22.15"W, 35d21'58.63"N)
Band 1 Block=512x512 Type=Float32, ColorInterp=Gray
? Min=669.509 Max=1604.949
? Minimum=669.509, Maximum=1604.949, Mean=988.295, StdDev=159.804
? NoData Value=-999999
? Overviews: 5006x5006, 2503x2503, 1251x1251, 625x625, 312x312
? Unit Type: US survey foot
? Metadata:
? ? STATISTICS_APPROXIMATE=YES
? ? STATISTICS_MAXIMUM=1604.9490966797
? ? STATISTICS_MEAN=988.29463693706
? ? STATISTICS_MINIMUM=669.50915527344
? ? STATISTICS_STDDEV=159.80361228109
? ? STATISTICS_VALID_PERCENT=100
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240321/68938236/attachment-0001.htm>
Message: 2
Date: Thu, 21 Mar 2024 21:49:55 +0100
From: Even Rouault <even.rouault at spatialys.com<mailto:even.rouault at spatialys.com>>
To: Conrad Bielski <conrad_bielski at yahoo.com<mailto:conrad_bielski at yahoo.com>>,
Subject: Re: [gdal-dev] USGS 3DEP (3D Elevation Program) - feet should
    be metres, how can I fix this?
Message-ID: <7832c1d9-61ce-41b0-b524-2f00859c817a at spatialys.com<mailto:7832c1d9-61ce-41b0-b524-2f00859c817a at spatialys.com>>
Content-Type: text/plain; charset="utf-8"; Format="flowed"
Le 21/03/2024 ? 21:45, Conrad Bielski via gdal-dev a ?crit?:
> Hello GDALers,
There's no such thing as a GEOTIFF tag 42114.
The closest tags are:
#define TIFFTAG_GDAL_METADATA 42112
#define TIFFTAG_GDAL_NODATA 42113
It would be helpuful if you could provide the file, or the result of a
"tiffdump -m 1000 the.tif" and "listgeo the.tif" on it.
And was the .tif.aux.xml provided with the TIFF, or computed by GDAL.
Because the information might come from it too.
> Have a great day,
> Conrad
> Files:
> ? ? USAGE[
> West Virginia."],
> Metadata:
> ? COMPRESSION=LZW
> ? INTERLEAVE=BAND
> ? LAYOUT=COG
> ? PREDICTOR=3
> Corner Coordinates:
> *Unit Type: US survey foot*
> ? Metadata:
http://www.spatialys.com<http://www.spatialys.com/>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240321/1e68a1d4/attachment.htm>
Subject: Digest Footer
End of gdal-dev Digest, Vol 238, Issue 82
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240325/1e2538cf/attachment-0001.htm>
