[gdal-dev] GDAL Maintainers Meeting Minutes
Howard Butler howard at hobu.co
Fri Mar 29 10:20:58 PDT 2024
Howard Butler, Even Rouault, Dan Baston, Javier Jiminez Shaw, and Sean Gillies held the monthly GDAL Maintainers Meeting on 03/28/2024. The following items were discussed and reported upon:
Sponsorship Updates
* Dynamic Graphic, Inc. sponsored GDAL at Supporter level
Discussion Items
 GDAL 3.8.5 RC1 is expected next week. It is intended to be the final 3.8 maintenance release with 3.9.0 being expected in May 2024
Maintenance activities update
Dan
* Addressed a few Python bindings crash bugs
* Python API documentation cleanups and reorganization to make discovery of methods groups by typical usage stories
Alessandro
* GDAL PR reviews
    * Vector file with Polygon Z with 2 coords causing errors https://github.com/OSGeo/gdal/issues/9326
    * GTiff: endless loop when resampling (bilinear) under some circumstances https://github.com/OSGeo/gdal/issues/9427
    *Inconsistent Output Dimensions from gdal.warp() with Identical outputBounds https://github.com/OSGeo/gdal/issues/9467
* Small improvement to code formatting to add line breaks after methods definition https://github.com/OSGeo/gdal/pull/9498
Even
* Exploring implementation of a consistent argument parsing library for all of the GDAL and OGR command line utilities. This library-wide update will provide a number of quality-of-life improvements for users of the command line utilities:
  * Usage messages will be consistently formatted
  * Longer help messages
  * Multiple specification of the same arguments should work more consistently and not fail silently in some cases
  * Potential for leverage of same framework to specify input for driving CLI activity with config files
  * Ability to remove lots of boilerplate CLI parsing code in the utilities
* RFC99 was merged that provided preliminary implementation to address management and bookkeeping of coordinate precision in OGR drivers that can leverage it. See https://github.com/rouault/gdal/blob/rfc99_text/doc/source/development/rfc/rfc99_geometry_coordinate_precision.rst for discussion
* Facilitated the release of OpenJPEG 2.5.2. See https://github.com/uclouvain/openjpeg/releases/tag/v2.5.2 for more information
* libtiff PSC motion passed and the project is now managed under GDAL-like processes
* Added a getDataset method on Layers to ensure that library users are not required to memoize Layer/Dataset relationships
* Action on over 100 tickets and PRs
The next GDAL Maintainers Meeting is 04/25/2024 at 9:00 EDT. Any PSC members are welcome to join by reaching out to me for an invite.
Howard
